Trying make a bridge betwhen 2 sxt
Ap
add name=bridge1
set [ find default-name=ether1 ] name=ether1-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=\
20/40mhz-ht-above disabled=no l2mtu=2290 mode=bridge name=wlan1-gateway \
nv2-cell-radius=10 nv2-preshared-key=lollollol nv2-security=enabled ssid=\
MikroTik wireless-protocol=nv2
/ip neighbor discovery
set wlan1-gateway discover=no
add address-pool=default-dhcp interface=ether1-local name=default
/tool user-manager customer
set admin access=\
own-routers,own-users,own-profiles,own-limits,config-payment-gw
add bridge=bridge1 interface=wlan1-gateway
add bridge=bridge1 interface=ether1-local
add address=192.168.88.1/24 comment="default configuration" disabled=yes \
interface=ether1-local network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=\
no interface=bridge1
add address=192.168.88.0/24 comment="default configuration" gateway=\
192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=\
established,related
# in/out-interface matcher not possible when interface (wlan1-gateway) is slav
use master instead (bridge1)
add action=drop chain=input comment="default configuration" in-interface=\
wlan1-gateway
add chain=forward comment="default configuration" connection-state=\
established,related
add action=drop chain=forward comment="default configuration" \
connection-state=invalid
connection-nat-state=!dstnat connection-state=new in-interface=\
wlan1-gateway
add action=masquerade chain=srcnat comment="default configuration" disabled=\
yes out-interface=wlan1-gateway
Client
add mtu=1500 name=bridge1
/interface wireless
20/40mhz-ht-above country=norway disabled=no l2mtu=2290 mode=\
station-bridge name=wlan1-gateway nv2-cell-radius=10 ssid=MikroTik \
wireless-protocol=nv2-nstreme-802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=\
tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik \
unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=lollollol \
wpa2-pre-shared-key=lollollol
add address=192.168.1.89/24 comment="default configuration" interface=\
ether1-local network=192.168.1.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=\
bridge1
add address=192.168.88.0/24 comment="default configuration" dns-server=\
192.168.88.1 gateway=192.168.88.1 netmask=24
/ip dns static
add address=192.168.1.89 name=router
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
wlan1-gateway
established
add chain=forward comment="default configuration" connection-state=related
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/romon port
add disabled=no
/system clock
set time-zone-autodetect=no
/system identity
set name=client1
/system leds
set 0 interface=wlan1-gateway
/tool mac-server
add interface=ether1-local
/tool mac-server mac-winbox
The client wont connect it status windows says: searching network
