My knowledge of RouterOS is limited, so can someone please confirm that this configuration is good to use for a routerboard that i now just want to use as a switch. I will connect ether1 to my ISP where i get 5 external IP-addresses, the other ether port shall then give the inserted gear external IP’s.
Any changes i should make to the configuration for optimation?
RouterBOARD 962UiGS-5HacT2HnT
MikroTik RouterOS 6.41.2
add admin-mac=64:D1:54:56:2F:E8 auto-mac=no comment=defconf igmp-snooping=yes
name=bridge1
/interface ethernet switch
set 0 name=MasterSwitch
add name=WAN
add name=LAN
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha512 enc-algorithms=
aes-256-cbc,aes-256-gcm
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=bridge1 interface=sfp1
add interface=ether1 list=WAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=sfp1 list=LAN
/ip dns static
add address=192.168.10.3 name=router
add action=accept chain=forward comment=“defconf: accept established,related”
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ip upnp
set show-dummy-rule=no
/system clock
set time-zone-name=Europe/Stockholm
/system identity
set name=“RouterOS Bridge”
/system leds
set 0 leds=“” type=off
set 1 type=off
set 2 type=off
/system logging
set 0 disabled=yes
add disabled=yes topics=debug
/system routerboard settings
set boot-protocol=dhcp silent-boot=yes
/system scheduler
add interval=12h name=Update_RouterOS on-event=Auto_Update_RouterOS policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon
start-date=aug/13/2017 start-time=03:00:00
/system script
add name=Auto_Update_RouterOS owner=admin policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=“/
system package update\r
\ncheck-for-updates once\r
\n:delay 1s;\r
\n:if ( [get status] = "New version is available") do={ install }”
/system watchdog
set automatic-supout=no no-ping-delay=0ms watchdog-timer=no
