Bridge statistics on hAP ac^2
Dear Forum members,
I’m looking for help to understand bridge traffic statistics. I have the following bridge port setup:
bridge
[admin@hAPac^2] > /interface bridge port print where bridge=bridge
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE                                                          BRIDGE                                                          HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0     wlan1_2.4GHz                                                       bridge        1     0x80         10                 10       none
 1     wlan2_5GHz                                                         bridge        1     0x80         10                 10       none
 2   H ether1                                                             bridge                                                          yes    1     0x80         10                 10       none
 3   H ether3                                                             bridge                                                          yes    1     0x80         10                 10       none
 4   H ether4                                                             bridge                                                          yes    1     0x80         10                 10       none
 5 I H ether5                                                             bridge                                                          yes    1     0x80         10                 10       none
bridge-test
[admin@hAPac^2] > /interface bridge port print where bridge=bridge-test
 0     ether2                                                             bridge-test                                                     yes    1     0x80         10                 10       none
 1     eoip-tunnel1                                                       bridge-test                                                            1     0x80         10                 10       none
 2     wlan_4_eoip                                                        bridge-test                                                            1     0x80         10                 10       none
On the ether2 port I have a client device connected, which is joining to a multicast stream over EOIP link. The EOIP link’s remote end is reached over internet, the uplink is ether1. Ether1 is part of bridge interface named bridge.
I would expect that on bridge-test interface I would see roughly the same traffic statistics like on ether2, assuming that there is no other traffic generated on wlan_4_eoip interface. However, when I check statistics in Winbox, I see 0 bps:
Can someone please explain me the behaviour? Why I see 0 bps on Rx/Tx on bridge-test interface? Router is hAP ac^2, with 6.43rc11.
Thank you in advance.
Does anyone can help me answering above? Or more clarifications would be needed? Thanks.
