I have a bridge that is bound to my customers and these bridge also contains my antennas. On Port 9 (which is my Mimosa PtP bakchaul device) I keep getting the error below;
My bridge config;
0 R ;;; PPPoE Bridge
name="pppoe+hs" mtu=1500 actual-mtu=1500 l2mtu=1590 arp=enabled
arp-timeout=auto mac-address=4C:5E:0C:**:**:** protocol-mode=rstp
fast-forward=no igmp-snooping=no auto-mac=yes ageing-time=5m
priority=0x8000 max-message-age=20s forward-delay=15s
transmit-hold-count=6 vlan-filtering=no dhcp-snooping=no
and this is my wan bridge;
1 R name="wanbridge" mtu=auto actual-mtu=1500 l2mtu=1590 arp=enabled
Ethernet port that I’m having issue with;
Flags: X - disabled, R - running, S - slave
0 RS ;;; MIMOSA_HQ
name="ether9" default-name="ether9" mtu=1500 l2mtu=1590
mac-address=4C:5E:0C:**:**:** orig-mac-address=4C:5E:0C:**:**:**
arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off
loop-protect-send-interval=5s loop-protect-disable-time=5m
auto-negotiation=yes advertise=10M-full,100M-full,1000M-full
full-duplex=yes tx-flow-control=auto rx-flow-control=auto speed=100Mbps
bandwidth=unlimited/unlimited
Current status of Port 9 (Mimosa)
/interface bridge port monitor
numbers: 4
interface: ether9
status: in-bridge
port-number: 6
role: designated-port
edge-port: no
edge-port-discovery: yes
point-to-point-port: yes
external-fdb: no
sending-rstp: yes
learning: yes
forwarding: yes
Right after this happens, I see my customers tries to re-auth on PPPoE server which closes previous connections and re-iniates a new one.
Could this be a cable issue or any configuration issue?
Thanks in advance for any suggestion, this is very important to me.
