bridge sxt and 433ah
in sxt, ether1 and wlan1 is bridged. and bridge has 192.168.1.53/24 ip.
in rb433 ether 3 has 192.168.1.52/24
my rb433 connected to sxt with ether 3
now the problem is that i can ping sxt from rb433 but cant ping other 192.168.1.x device that connected to wlan1(sxt)
note that sxt can ping them!
What Version ROS are you using, and are you using WDS? What Extensions are you using? 802.11 Nstreme or Nv2?
Do you have the SXT in Station mode or Station Bridge?
i assume the RB433 is AP Bridge..
need more info.
