Is it possible to bridge the router (mikrotik routeOS v5.15) to get the direct connection to the internet network?
I need this possibility because mikrotik seems not to be able to serve some UDP protocols.
So i have to connect computer directly to the adsl several times a week
Because I can’t connect for example to o2 voip management using ports 2205, 2207 or to RTMFP server
So I need the possibility to work with internet directly without mikrotik proxy.
It’s an emergency solution, but it’s a bit comfortable than repluging cables
If you’re using NAT and don’t want to expose your entire network by bridging to the internet, you could add an explicit NAT-All rule at the end of your nat config to create a DMZ to a required machine. The advantage being that you could enable and disable the rules only when you needed them.
