This router is been a personal experiance and using it to learn.
I have a couple of issues and cant seem to find anything that relates to troubleshooting this. Would appreciate points and explanations why things arnt working as i had intended.
Trying to figure out why Bridge is passing packets through firewall.
DNS server also does not respond to requests.
# 2023-11-10 13:01:02 by RouterOS 7.12rc7
# software id = X23X-V6AT
# model = C52iG-5HaxD2HaxD
# serial number = HE708ZJWWS4
add igmp-snooping=yes multicast-querier=yes name=Bridge
set [ find default-name=ether1 ] arp-timeout=1d l2mtu=1500 mtu=1492
add comment=defconf name=WAN
add name=ISP
add comment=Wireless name=WLAN
add comment=defconf include=WLAN name=LAN
/interface wifiwave2 datapath
add bridge=Bridge comment=defcon disabled=no interface-list=WLAN name=\
datapath
/interface wifiwave2 security
add authentication-types="" disabled=no name=OPTUSVD325F7A0
set [ find default-name=wifi2 ] arp-timeout=5s channel.band=2ghz-ax .width=\
20/40mhz-Ce configuration.antenna-gain=8 .country=Australia .mode=ap \
.ssid=OPTUSVD325F7A0 datapath=datapath disabled=no mtu=1500 name=2GHz \
security=OPTUSVD325F7A0 security.authentication-types=wpa2-psk \
.encryption=ccmp,gcmp,ccmp-256,gcmp-256
set [ find default-name=wifi1 ] channel.band=5ghz-ax .width=20/40/80mhz \
configuration.country=Australia .mode=ap .ssid=OPTUSVD325F7A0_5GHz \
datapath=datapath disabled=no mtu=1500 name=5GHz security=OPTUSVD325F7A0 \
security.authentication-types=wpa2-psk,wpa3-psk .encryption=\
/ip ipsec mode-config
add connection-mark=ProtonVPN name=ProtonVPN responder=no
/ip ipsec policy group
add name=ProtonVPN
/ip ipsec profile
add dh-group=modp4096,modp2048,modp1024 dpd-interval=disable-dpd \
enc-algorithm=aes-256 hash-algorithm=sha256 name=ProtonVPN
/ip ipsec peer
add address=nl-free-145.protonvpn.net disabled=yes exchange-mode=ike2 name=\
"ProtonVPN nl-free-145" profile=ProtonVPN
/ip ipsec proposal
add auth-algorithms=sha256 disabled=yes enc-algorithms=aes-256-cbc lifetime=\
0s name=ProtonVPN pfs-group=none
add name=dhcp_pool1 ranges=192.168.88.10-192.168.88.254
add add-arp=yes address-pool=dhcp_pool1 interface=Bridge name=dhcp1 \
server-address=192.168.88.1
/ipv6 dhcp-server option
add code=12 name=Ident value=0x000001
/ipv6 dhcp-server option sets
add name=defcon options=Ident
/ipv6 pool
add name=6-4 prefix=::/80 prefix-length=96
/ppp profile
add bridge-path-cost=5 dns-server=10.7.0.1 name="Proto VPN" use-compression=\
no
/queue type
add kind=pcq name=pcq-large-download pcq-burst-time=8s pcq-classifier=\
dst-address,src-port pcq-limit=80KiB pcq-total-limit=1024KiB
/queue tree
add name=ISP parent=global queue=ethernet-default
add bucket-size=0.08 burst-limit=57M burst-time=30s limit-at=20k max-limit=\
50M name=ISP_In packet-mark=catchall_in parent=ISP priority=5 queue=\
ethernet-default
add name=HTTP_in packet-mark=HTTP_In parent=ISP_In priority=7 queue=\
pcq-large-download
add name=HTTP_Streaming_in packet-mark=HTTP_Streaming_in parent=ISP_In \
priority=6 queue=pcq-download-default
add name=DSTNAT_in packet-mark=DSTNAT_IN parent=ISP_In priority=2 queue=\
add name=QUIC_in packet-mark=Quic_in parent=ISP_In priority=4 queue=\
add bucket-size=0.08 burst-limit=27M burst-time=30s limit-at=20k max-limit=\
20M name=ISP_Out packet-mark=catchall_out parent=ISP priority=5 queue=\
ethernet-default
add name=DSTNAT_out packet-mark=DSTNAT_out parent=ISP_Out
add name=HTTP_out packet-mark=HTTP_out parent=ISP_Out
add name=HTTP_Streaming_out packet-mark=HTTP_Streaming_out parent=ISP_Out
add name=Quic_out packet-mark=Quic_out parent=ISP_Out
add name=LServer_In packet-mark=LServer_IN parent=ISP_In priority=3
add name=LServer_Out packet-mark=LServer_OUT parent=ISP_Out
/dude
set enabled=yes
add bridge=Bridge interface=ether2
add bridge=Bridge interface=ether3
add bridge=Bridge interface=ether4
add bridge=Bridge comment=ISP disabled=yes interface=ether5
add bridge=Bridge interface=2GHz
add bridge=Bridge interface=5GHz
add bridge=Bridge interface=ether1
set enabled=yes icmp-timeout=4s udp-timeout=4s
/ipv6 settings
set disable-ipv6=yes
/interface detect-internet
set detect-interface-list=all internet-interface-list=ISP lan-interface-list=\
LAN wan-interface-list=WAN
add interface=Bridge list=LAN
add interface=ether5 list=ISP
add address=192.168.88.1/24 comment=defconf interface=Bridge network=\
192.168.88.0
/ip dhcp-client
add comment=ISP interface=ether5 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.88.147 client-id=1:2c:26:17:e7:ec:4f comment=\
"Occulus Rift 2" mac-address=2C:26:17:E7:EC:4F
add address=192.168.88.100 client-id=1:dc:e9:94:1b:42:37 comment=\
"Brother MFC-L2713DW - Study" mac-address=DC:E9:94:1B:42:37
add address=192.168.88.253 mac-address=54:80:28:4B:3A:58
add address=192.168.88.254 client-id=1:d4:5d:64:55:1f:fa mac-address=\
D4:5D:64:55:1F:FA
add address=192.168.88.0/24 dns-server=1.1.1.1,8.8.4.4 gateway=192.168.88.1 \
ntp-server=192.168.88.1
set cache-max-ttl=3d verify-doh-cert=yes
/ip dns static
add address=127.0.0.1 name=localhost
/ip firewall address-list
add address=dns.google list="Google DNS"
add address=discord.com list=Discord
add address=6136c3852a51.duckdns.org list=DuckDNS
add address=cloudflare-dns.com list=Cloudflare
add action=fasttrack-connection chain=forward comment=FastTrack \
connection-mark=DNS connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related" \
"defconf: drop all from ISP not DSTNATed" connection-nat-state=!dstnat \
connection-state=new in-interface-list=ISP
connection-state=invalid
"defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1 \
in-interface-list=!ISP
ipsec-policy=out,ipsec
ipsec-policy=in,ipsec
in-interface-list=!LAN
add action=accept chain=forward connection-state=related in-interface-list=\
ISP
/ip firewall mangle
add action=mark-connection chain=output comment=DNS dst-port=53 \
new-connection-mark=DNS passthrough=yes protocol=udp
add action=mark-connection chain=output dst-port=53 new-connection-mark=DNS \
passthrough=yes protocol=tcp
add action=fasttrack-connection chain=output connection-mark=DNS
add action=add-src-to-address-list address-list=LServer-DSTNat \
address-list-timeout=4h chain=forward comment=LServer \
connection-nat-state=dstnat connection-state=established,related \
dst-address=192.168.88.253 fragment=no in-interface-list=ISP log-prefix=\
LServer-DSTNat
address-list-timeout=5m chain=input connection-nat-state=dstnat \
connection-state=new dst-address=192.168.88.253 in-interface-list=ISP
add action=mark-connection chain=prerouting comment="Mark ICMP" \
connection-state=established,related,new in-interface-list=!LAN \
new-connection-mark=ICMP passthrough=no protocol=icmp
add action=mark-connection chain=forward comment=LServer connection-state=\
related,new new-connection-mark=LServer passthrough=yes src-address-list=\
LServer-DSTNat
add action=mark-packet chain=prerouting connection-mark=LServer \
in-interface-list=ISP new-packet-mark=LServer_IN passthrough=no
add action=mark-packet chain=forward connection-mark=LServer new-packet-mark=\
LServer_OUT out-interface-list=ISP passthrough=no
add action=mark-connection chain=forward comment="Mark HTTP" \
connection-state=related,new dst-port=80,443 new-connection-mark=HTTP \
add action=mark-connection chain=forward connection-state=related,new \
dst-port=80,443 new-connection-mark=QUIC passthrough=yes protocol=udp
add action=mark-packet chain=prerouting connection-mark=HTTP \
in-interface-list=ISP new-packet-mark=HTTP_In passthrough=no
add action=mark-packet chain=forward connection-mark=HTTP new-packet-mark=\
HTTP_out out-interface-list=ISP passthrough=no
add action=mark-packet chain=prerouting connection-mark=QUIC \
in-interface-list=ISP new-packet-mark=Quic_in passthrough=no
add action=mark-packet chain=forward connection-mark=QUIC new-packet-mark=\
Quic_out out-interface-list=ISP passthrough=no
add action=mark-connection chain=forward comment="Mark HTTP_Streaming" \
connection-state=related,new new-connection-mark=HTTP_Streaming \
passthrough=yes port=1935 protocol=tcp
new-connection-mark=HTTP_Streaming passthrough=yes port=1935 protocol=udp
add action=mark-packet chain=prerouting connection-mark=HTTP_Streaming \
in-interface-list=ISP new-packet-mark=HTTP_Streaming_in passthrough=yes
add action=mark-packet chain=forward connection-mark=HTTP_Streaming \
new-packet-mark=HTTP_Streaming_out out-interface-list=ISP passthrough=yes
add action=mark-connection chain=input comment=ISP connection-mark=no-mark \
connection-state=established,related,new,untracked in-interface-list=!LAN \
new-connection-mark=ISP passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark \
add action=mark-packet chain=input connection-mark=ISP in-interface-list=ISP \
new-packet-mark=catchall_in passthrough=yes
add action=mark-packet chain=forward connection-mark=ISP new-packet-mark=\
catchall_out out-interface-list=ISP passthrough=yes
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
add action=src-nat chain=srcnat disabled=yes dst-address=192.168.89.0/24 \
src-address=192.168.88.0/24 to-addresses=192.168.89.0/24
add action=src-nat chain=srcnat disabled=yes dst-address=192.168.88.0/24 \
src-address=192.168.89.0/24 to-addresses=192.168.88.0/24
add action=dst-nat chain=dstnat comment="SSH - LServer" dst-port=2223 \
in-interface-list=ISP log-prefix=LServer-DSTNat protocol=tcp \
to-addresses=192.168.88.253 to-ports=2223
add action=dst-nat chain=dstnat dst-port=81 in-interface-list=ISP protocol=\
tcp to-addresses=192.168.88.253 to-ports=81
add action=dst-nat chain=dstnat comment=Icecast disabled=yes dst-port=8000 \
in-interface-list=ISP protocol=tcp to-addresses=192.168.88.254 to-ports=\
8000
add action=dst-nat chain=dstnat comment=Neverwinter disabled=yes dst-port=\
5121 in-interface-list=ISP protocol=tcp to-addresses=192.168.88.254 \
to-ports=5121
add action=dst-nat chain=dstnat disabled=yes dst-port=6667 in-interface-list=\
ISP protocol=udp to-addresses=192.168.88.254 to-ports=6667
add action=dst-nat chain=dstnat disabled=yes dst-port=28900 \
in-interface-list=ISP protocol=udp to-addresses=192.168.88.254 to-ports=\
28900
add action=dst-nat chain=dstnat disabled=yes dst-port=27900 \
27900
add action=dst-nat chain=dstnat disabled=yes dst-port=6500 in-interface-list=\
ISP protocol=udp to-addresses=192.168.88.254 to-ports=6500
add action=dst-nat chain=dstnat disabled=yes dst-port=5300 in-interface-list=\
ISP protocol=udp to-addresses=192.168.88.254 to-ports=5300
add action=dst-nat chain=dstnat disabled=yes dst-port=512 in-interface-list=\
ISP protocol=udp to-addresses=192.168.88.254 to-ports=512
add action=dst-nat chain=dstnat comment=Factorio disabled=yes dst-port=34197 \
34197
add action=dst-nat chain=dstnat disabled=yes dst-port=34197 \
34197
add action=dst-nat chain=dstnat disabled=yes dst-port=61621 \
61621
add action=dst-nat chain=dstnat comment=SotS disabled=yes dst-port=3369 \
3369
add action=dst-nat chain=dstnat disabled=yes dst-port=3369 in-interface-list=\
ISP protocol=udp to-addresses=192.168.88.254 to-ports=3369
add action=dst-nat chain=dstnat comment=Minecraft dst-port=25565 \
25565
add action=dst-nat chain=dstnat dst-port=25565 in-interface-list=ISP \
protocol=udp to-addresses=192.168.88.254 to-ports=25565
add action=dst-nat chain=dstnat comment=Starbound disabled=yes dst-port=21025 \
21025
add action=dst-nat chain=dstnat comment=Steam disabled=yes dst-port=27015 \
27015
add action=dst-nat chain=dstnat disabled=yes dst-port=27036 \
27036
add action=dst-nat chain=dstnat disabled=yes dst-port=27031-27036 \
27031-27036
add action=dst-nat chain=dstnat disabled=yes dst-port=27015 \
27015
add action=dst-nat chain=dstnat comment="Skyrim: Together" disabled=yes \
dst-port=10578 in-interface-list=ISP protocol=udp to-addresses=\
192.168.88.254 to-ports=10578
add action=dst-nat chain=dstnat comment=Veloren disabled=yes dst-port=14004 \
14004
add action=dst-nat chain=dstnat disabled=yes dst-port=14004 \
14004
add action=dst-nat chain=dstnat disabled=yes dst-port=14005 \
14005
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set pptp disabled=yes
/ip ipsec identity
add auth-method=eap certificate=ca_ovpn-import1693628031 disabled=yes \
eap-methods=eap-mschapv2 generate-policy=port-strict mode-config=\
ProtonVPN peer="ProtonVPN nl-free-145" policy-template-group=ProtonVPN \
username=G7UwvJEhNKNOWvBt
/ip ipsec policy
add comment="Proton VPN" disabled=yes group=ProtonVPN proposal=ProtonVPN \
template=yes
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
/ip smb
set interfaces=*8
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether1 type=external
add interface=*8 type=internal
/ipv6 address
add address=::/96 advertise=no from-pool=6to4 interface=*8
/ipv6 firewall address-list
/ipv6 firewall filter
established,related,untracked
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ipv6 nd
set [ find default=yes ] interface=*8 managed-address-configuration=yes \
other-configuration=yes ra-lifetime=none
/ipv6 nd prefix
add interface=*8
/system clock
set time-zone-name=Australia/Brisbane
/system logging
add disabled=yes topics=ovpn,debug
add disabled=yes topics=ipsec,info
add disabled=yes topics=dns,debug
add disabled=yes topics=debug,!packet
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address=0.au.pool.ntp.org
add address=0.oceania.pool.ntp.org
add address=1.oceania.pool.ntp.org
add address=2.oceania.pool.ntp.org
/system watchdog
set ping-start-after-boot=4h watchdog-timer=no
/tool graphing
set store-every=hour
/tool mac-server
/tool mac-server mac-winbox
