Bridge VLAN filtering and routing help
I am trying to configure the setup in the diagram, and it is mostly working but am stuck with routing VLANs to the firewall.
I have VLAN 30 and 50 in the bridge and they can route to each other fine. Each of the core switches can reach public networks via 10.10.10.6 but a client on VLAN 30 or 50 can only reach the core switch IP in VLAN 10 - 10.10.10.0/29 and not 10.10.10.6 or anything public.
I have tried simplifying the WAN by putting an address on an interface but I get the same issue.
I am probably missing something obvious but very grateful if someone can point it out, or if I am going about this in the wrong way. Relevant config from core-01 below, core-02 is almost identical. Thanks!
add admin-mac=AB:CD:EF:06:0D:D8 ageing-time=5m arp=enabled arp-timeout=auto auto-mac=no dhcp-snooping=no disabled=no ether-type=0x8100 fast-forward=yes forward-delay=15s frame-types=admit-all \
    igmp-snooping=no ingress-filtering=yes max-message-age=20s mtu=auto name=br-mlag priority=0x1000 protocol-mode=rstp pvid=99 transmit-hold-count=6 vlan-filtering=yes
/interface vlan
add arp=enabled arp-timeout=auto disabled=no interface=br-mlag loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mtu=1500 name=vlan-client use-service-tag=no \
    vlan-id=50
add arp=enabled arp-timeout=auto disabled=no interface=br-mlag loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mtu=1500 name=vlan-management use-service-tag=no \
    vlan-id=30
add arp=enabled arp-timeout=auto disabled=no interface=br-mlag loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mtu=1500 name=vlan-wan use-service-tag=no \
    vlan-id=10
/interface bonding
add arp=enabled arp-interval=100ms arp-ip-targets="" arp-timeout=auto disabled=no down-delay=0ms !forced-mac-address lacp-rate=30secs link-monitoring=mii mii-interval=100ms min-links=0 \
    mlag-id=11 mode=802.3ad mtu=1500 name=mlag-01 primary=none slaves=01 transmit-hash-policy=layer-2 up-delay=0ms
    mlag-id=12 mode=802.3ad mtu=1500 name=mlag-02 primary=none slaves=02 transmit-hash-policy=layer-2 up-delay=0ms
add arp=enabled arp-interval=100ms arp-ip-targets="" arp-timeout=auto disabled=no down-delay=0ms !forced-mac-address lacp-rate=30secs link-monitoring=mii mii-interval=100ms min-links=0 mode=\
    802.3ad mtu=1500 name=mlag-wan primary=none slaves=13-wan transmit-hash-policy=layer-2 up-delay=0ms
    802.3ad mtu=1500 name=peer primary=none slaves=16 transmit-hash-policy=layer-2 up-delay=0ms
/interface vrrp
add arp=enabled arp-timeout=auto authentication=none disabled=no group-master="" interface=vlan-client interval=1s mtu=1500 name=vrrp-client on-backup="" on-fail="" on-master="" \
    preemption-mode=yes priority=200 remote-address=10.10.50.4 sync-connection-tracking=yes v3-protocol=ipv4 version=3 vrid=50
add arp=enabled arp-timeout=auto authentication=none disabled=no group-master="" interface=vlan-management interval=1s mtu=1500 name=vrrp-management on-backup="" on-fail="" on-master="" \
    preemption-mode=yes priority=200 remote-address=10.10.30.4 sync-connection-tracking=yes v3-protocol=ipv4 version=3 vrid=30
/interface bridge mlag
set bridge=br-mlag peer-port=peer
add auto-isolate=no bpdu-guard=no bridge=br-oob broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=yes interface=eth-01 \
    internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no \
    unknown-multicast-flood=yes unknown-unicast-flood=yes
add auto-isolate=no bpdu-guard=no bridge=br-mlag broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=yes interface=peer \
    internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 pvid=99 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no \
add auto-isolate=no bpdu-guard=no bridge=br-mlag broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=yes interface=mlag-01 \
add auto-isolate=no bpdu-guard=no bridge=br-mlag broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none ingress-filtering=yes interface=vlan-management \
    internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 pvid=30 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no \
add auto-isolate=no bpdu-guard=no bridge=br-mlag broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none ingress-filtering=yes interface=vlan-client \
    internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 pvid=50 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no \
add auto-isolate=no bpdu-guard=no bridge=br-mlag broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=yes interface=mlag-02 \
add auto-isolate=no bpdu-guard=no bridge=br-mlag broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=yes interface=mlag-wan \
    internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 point-to-point=auto priority=0x80 pvid=10 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no \
add auto-isolate=no bpdu-guard=no bridge=br-mlag broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none ingress-filtering=yes interface=vlan-wan \
/interface bridge vlan
add bridge=br-mlag disabled=no tagged=br-mlag,peer,mlag-01,mlag-02 untagged="" vlan-ids=30
add bridge=br-mlag disabled=no tagged=br-mlag,peer,mlag-01,mlag-02 untagged="" vlan-ids=50
add bridge=br-mlag disabled=no tagged=br-mlag,peer untagged="" vlan-ids=10
add address=172.31.255.1/24 disabled=no interface=br-oob network=172.31.255.0
add address=10.10.30.3/24 disabled=no interface=vlan-management network=10.10.30.0
add address=10.10.50.3/24 disabled=no interface=vlan-client network=10.10.50.0
add address=10.10.30.1/32 disabled=no interface=vrrp-management network=10.10.30.1
add address=10.10.50.1/32 disabled=no interface=vrrp-client network=10.10.50.1
add address=10.10.10.3/29 disabled=no interface=vlan-wan network=10.10.10.0
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.10.10.6 pref-src="" routing-table=main suppress-hw-offload=no
Routing over MLAG is typically something you want to avoid even in mature MLAG implementations like Cisco and Juniper. MikroTik’s implementation is really only intended for L2 and even when L3 over MLAG is officially supported, i would still avoid it as a network designer.
Here is a great deep dive from Ivan Pepelnjak on why this is a bad idea: https://blog.ipspace.net/2022/12/mlag-routing.html
I’d change the MLAG-WAN into independently routed links between each CRS317 and the Firewall. While you could use static routing, OSPF would be a better choice.
Thanks, yes, it is not really necessary so I’ll take that out. Even with simple links to the WAN I am not able to route VLAN 30 and 50 to the WAN. Am I missing something in the bridge ports / VLAN table?
