I’d like to use the VLAN filtering capability on a HAP AC2. No HW chip VLAN settings are used, all are on defaults since I want to use the bridge facility for this entirely. This is the config I’m using:
When I ping for instance 192.168.1.65 vlan-filtering=no, it works and other traffic also passes. When I change it to vlan-filtering=yes, traffic stops going out on VLAN 20. I can see broadcasts coming in on VLAN 20, though. This seems a simple enough configuration to me, yet it fails. What did I overlook?
Thanks, I did that, but it didn’t help. It’s not an inter-VLAN routing problem, though, since I have only one VLAN. Unless I’m misunderstanding something, of course.
From the full config you can see that ether5 is added to bridge-lan, and that is the interface connected to a trunk port on a switch with vlan 20 where only tagged packets travel. If I add the vlan on ether5, it starts working, with vlan filtering turned on. It’s as if vlan filtering only allows traffic from/to tagged interfaces or something like that. Unfortunately the documentation is not very good regarding this.
The code assumes you want ether5 to carry tagged frames. You should also remove pvid=20 from definition of bridge-lan in /interface bridge as you’re using vlan20 interface to properly deal with traffic. Also setting pvid=20 for ether5 on /interface bridge port is redundant and should be removed.
If, on the other hand, you want to make ether5 access port for VLAN 20 (i.e. untagged frames live outside routerboard), then pvid setting on ether5 port in /interface bridge port is fine, but you have to change frame-types to admit-only-untagged-and-priority-tagged. The /interface bridge vlan setting above should be changed so that ether5 port is listed as untagged member port.
add admin-mac=CC:2D:E0:C2:CA:FB auto-mac=no name=bridge
add fast-forward=no frame-types=admit-only-vlan-tagged ingress-filtering=yes not sure if this is required…
name=bridge-lan protocol-mode=none pvid=20 vlan-filtering=yes Remove and should be the default pvid=1
add name=default-dhcp ranges=192.168.88.10-192.168.88.254 WHERE IS THE IP POOL FOR THE VLAN???
add address-pool=default-dhcp interface=bridge name=defconf WHERE IS THE DHCP-Server for the VLAN??
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=wlan1
add bridge=bridge interface=wlan2 add bridge=bridge-lan frame-types=admit-only-vlan-tagged ingress-filtering=
yes interface=ether5 pvid=20 TRY add bridge=bridge interface=ether5 pvid=20 ingress filtering=yes
I am assuming that this port leads to a device that is not able to tag or recognize tagged packets.
@sebastia, @mkx, thanks, one of these might be the overlook, I’ll try them and also anav’s suggestions.
@anav: thanks for the thorough inspection of the export, but please don’t mind all the defaults and missing bits (dhcp, pool, etc.), when I’ll have the vlan issue fixed, I’ll reconfigure the whole thing, it’s just an isolated test now for the bridge and vlans (for the live config), nothing else.
This one solved it, thanks! I know the PVIDs are redundant but they do practically nothing in this setup, so it doesn’t hurt either. ROS defaults to PVID 1 and I tend to change it from 1 to one of my VLAN IDs.
