Hi, I am unsure if what I am seeing is what should be occuring so I will post below the scenario in the hope that someone can comment.
Simple setup, a gateway, an AP and a CPE
Gateway
/interface vlan
add interface=ether3_Lan name=vlan10 vlan-id=10
add name=pool_vlan10 ranges=10.0.10.2-10.0.10.254
add address-pool=pool_vlan10 disabled=no interface=vlan10 lease-time=30s name=dhcp_vlan10
add address=10.0.10.1/24 interface=vlan10 network=10.0.10.0
add address=10.0.10.0/24 dns-server=10.0.10.1 gateway=10.0.10.1
AP
add name=bridge-vlan10 pvid=10 vlan-filtering=yes
/interface wireless
disabled=no mode=ap-bridge ssid=vlan10 vlan-id=10 vlan-mode=use-tag
/interface vlan
add interface=ether1 name=vlan10 vlan-id=10
add bridge=bridge-vlan10 interface=wlan1
add bridge=bridge-vlan10 interface=ether1
/interface bridge vlan
add bridge=bridge-vlan10 tagged=ether1,wlan1 vlan-ids=10
Now… the DHCP server successfully assigns IP address to the AP (10.0.10.2) and to the CPEs (10.0.10.x), everything seems to work as expected.
Try to access the AP with Winbox, all is good.
Now try to access the AP with mac telnet, nope, no go, wont connect.
Are these characteristics correct for the above setup ?
