I made this configuration on a CRS326-24G-2S+ with RouterOS 6.42 in order to obtain:
ether2 and sfp-sfpplus1 as trunk ports with untagged ip address by dhcp client, to reach and ping this switch from other trunk devices (switches, management pc);
ether1 access port with vlan 2012 for voip phones;
ether3 and ether4 access ports with vlan 2014 for video;
ether5 access port with vlan 2008 for control room;
ether6 to ether24 access ports with vlan 2000 for office computers;
ip addresses from dhcp over vlan 2012, 2008 and 2000 to reach and ping this switch from those access networks;
# jan/02/1970 07:48:47 by RouterOS 6.42
# software id = 7AF9-SIJP
# model = CRS326-24G-2S+
# serial number = 763E081A8E9E
add fast-forward=no name=bridge protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] comment="telefoni vlan2012"
set [ find default-name=ether2 ] comment="trunk port"
set [ find default-name=ether3 ] comment="video1 vlan2014"
set [ find default-name=ether4 ] comment="video2 vlan2014"
set [ find default-name=ether5 ] comment="domotica1 vlan2008"
set [ find default-name=sfp-sfpplus1 ] comment="trunk port"
/interface vlan
add interface=bridge name=vlan-domotica vlan-id=2008
add interface=bridge name=vlan-telefoni vlan-id=2012
add interface=bridge name=vlan-uffici vlan-id=2000
add interface=bridge name=vlan-videosorv vlan-id=2014
add bridge=bridge interface=ether24 pvid=2000
add bridge=bridge interface=sfp-sfpplus1
add bridge=bridge interface=ether23 pvid=2000
add bridge=bridge interface=ether22 pvid=2000
add bridge=bridge interface=ether21 pvid=2000
add bridge=bridge interface=ether20 pvid=2000
add bridge=bridge interface=ether19 pvid=2000
add bridge=bridge interface=ether18 pvid=2000
add bridge=bridge interface=ether17 pvid=2000
add bridge=bridge interface=ether16 pvid=2000
add bridge=bridge interface=ether15 pvid=2000
add bridge=bridge interface=ether14 pvid=2000
add bridge=bridge interface=ether13 pvid=2000
add bridge=bridge interface=ether12 pvid=2000
add bridge=bridge interface=ether11 pvid=2000
add bridge=bridge interface=ether10 pvid=2000
add bridge=bridge interface=ether9 pvid=2000
add bridge=bridge interface=ether8 pvid=2000
add bridge=bridge interface=ether7 pvid=2000
add bridge=bridge interface=ether6 pvid=2000
add bridge=bridge interface=ether5 pvid=2008
add bridge=bridge interface=ether4 pvid=2014
add bridge=bridge interface=ether3 pvid=2014
add bridge=bridge interface=ether1 pvid=2012
/interface bridge vlan
add bridge=bridge comment=uffici tagged=bridge,ether2,sfp-sfpplus1 untagged=\
ether24,ether23,ether22,ether21,ether20 vlan-ids=2000
add bridge=bridge untagged=ether2,sfp-sfpplus1 vlan-ids=1
add bridge=bridge comment=videosorveglianza tagged=bridge,ether2,sfp-sfpplus1 \
vlan-ids=2014
add bridge=bridge comment=telefoni tagged=bridge,ether2,sfp-sfpplus1 \
vlan-ids=2012
add bridge=bridge comment=domotica tagged=bridge,ether2,sfp-sfpplus1 \
vlan-ids=2008
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=bridge
add add-default-route=no dhcp-options=hostname,clientid disabled=no \
interface=vlan-uffici use-peer-dns=no use-peer-ntp=no
interface=vlan-telefoni use-peer-dns=no use-peer-ntp=no
interface=vlan-domotica use-peer-dns=no use-peer-ntp=no
/system routerboard settings
set boot-os=router-os silent-boot=no
It works.
As you can see, in this entry:
I put only ether20-ether24 as untagged ports, as described here: https://wiki.mikrotik.com/wiki/Manual:Interface/Bridge#Bridge_VLAN_Filtering
But also ether6-ether19 work as expected as access port on the vlan 2000.
And also ether1, 3, 4, 5 work as expected as access port on their respective vlan!
So, why the wiki examples ask to insert untagged ports in the /interface bridge vlan?
Are there any issue if I don’t insert them?
