Like the subject says.
I have one cvlan Vlan20 and one svlan 2100(outer)
Vlan 20 gives out 192.168.20.x at both locations (no overlap)
The currently uploaded config works, but I’m seeing 1svlan and 2cvlans come across the provider network.
If I send tagged vlan 20 traffic down vlan2100-QinQ20 for vlan 20, it works but has 3 vlan headers (1svlan 2cvlan)
If i send untagged vlan 20 traffic down vlan2100-QinQ20 it doesn’t work but the headers are correct (1svlan 1cvlan)
Also, if i add eth1-vlan2100 to the bridge and send tagged vlan 20 traffic down it, it has the correct headers but doesn’t work.
The only config I can get working is if it double tags the cvlan by sending tagged 20 down vlan2100-QinQ20 (which tags it again) and then it gets outer service tagged by eth1-vlan2100
See the working config below that has the duplicate cvlan headers.
# 2023-07-26 17:19:15 by RouterOS 7.10.2
# software id = XFZ0-5LYE
# model = RB750Gr3
# serial number = HEC08V9AWMB
add admin-mac=48:A9:8A:A9:85:6B auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
set [ find default-name=ether1 ] name=eth1-provider
/interface vlan
add interface=bridge name=main-vlan20 vlan-id=20
add interface=bridge name=main-vlan21 vlan-id=21
add interface=eth1-provider name=vlan2100 use-service-tag=yes vlan-id=2100
add interface=vlan2100 name=vlan2100-QinQ20 vlan-id=20
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
/ip hotspot profile
add name=Vlan20 ranges=192.168.20.10-192.168.20.20
add name=Vlan21 ranges=192.168.21.10-192.168.21.20
add address-pool=Vlan20 interface=main-vlan20 lease-time=10m name=Vlan20
add address-pool=Vlan21 interface=main-vlan21 lease-time=10m name=Vlan21
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether2 pvid=20
add bridge=bridge comment=defconf interface=ether3 pvid=21
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge interface=vlan2100-QinQ20
/ipv6 settings
/interface bridge vlan
add bridge=bridge tagged=bridge,vlan2100-QinQ20 untagged=ether2 vlan-ids=20
add bridge=bridge tagged=bridge untagged=ether3 vlan-ids=21
add comment=defconf interface=eth1-provider list=LAN
add interface=ether5 list=LAN
add interface=main-vlan20 list=LAN
add interface=main-vlan21 list=LAN
add interface=*9 list=LAN
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.1.1/24 comment=defconf interface=ether5 network=\
192.168.1.0
add address=192.168.20.1/24 interface=main-vlan20 network=192.168.20.0
add address=192.168.21.1/24 interface=main-vlan21 network=192.168.21.0
/ip dhcp-client
add comment=defconf disabled=yes interface=eth1-provider
add address=192.168.20.0/24 comment=defconf gateway=192.168.20.1
add address=192.168.21.0/24 comment=defconf gateway=192.168.21.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=forward connection-state=\
established,related,untracked
add action=accept chain=input connection-state=established,related,untracked
/routing bfd configuration
add disabled=no interfaces=all min-rx=200us min-tx=200us multiplier=5
/system clock
set time-zone-name=America/Detroit
/system identity
set name=Lab_A
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set file-name=pcapA.pcap filter-interface=eth1-provider filter-ip-protocol=\
icmp
# 2023-07-26 19:29:08 by RouterOS 7.10.2
# software id = Y4LK-Y9I9
# model = RB750Gr3
# serial number = HEC08PP06KE
add admin-mac=48:A9:8A:A9:88:76 auto-mac=no comment=defconf \
ingress-filtering=no name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] name=eth1-Provider
/interface vlan
add interface=eth1-Provider name=eth1-vlan2100 use-service-tag=yes vlan-id=\
2100
add interface=eth1-vlan2100 name=vlan2100-QinQ20 vlan-id=20
/interface lte apn
/ip hotspot profile
add name=Vlan20 ranges=192.168.20.30-192.168.20.40
add name=Vlan21 ranges=192.168.21.30-192.168.21.40
/port
set 0 name=serial0
add bridge=bridge interface=vlan2100-QinQ20 pvid=20
/ipv6 settings
add comment=defconf interface=eth1-Provider list=LAN
set auth=sha1,md5
add address=192.168.20.254/24 comment=defconf interface=main-vlan20 network=\
192.168.20.0
add address=192.168.1.1/24 interface=ether5 network=192.168.1.0
add address=192.168.21.254/24 comment=defconf interface=main-vlan21 network=\
192.168.21.0
/ip dhcp-client
add address=192.168.20.0/24 comment=defconf gateway=192.168.20.254
add address=192.168.21.0/24 comment=defconf gateway=192.168.21.254
/ip dns static
add disabled=no interfaces=all min-rx=200us min-tx=200us multiplier=5 vrf=\
main
/system clock
/system identity
set name=LAB_B
/system note
/tool mac-server
/tool sniffer
set file-name=pcap.pcap filter-interface=eth1-Provider filter-ip-protocol=\
icmp
