So downgraded back to 6.47 and dhcp client once again didnt come up.
Disabling RTSP on the bridge allows it to come up. Then i reboot and it doesnt. Change to none and it comes up. viscious circle
This is a cut down version without all firewall rules isolating networks / internet access / DNS redirection
7.0 i still couldnt get it to come up no matter what i did
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 6.47.1 (c) 1999-2020 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
[admin@MikroTik] > /export hide-sensitive
# jul/21/2020 13:36:52 by RouterOS 6.47.1
# software id = 9WBF-D6CP
# model = RouterBOARD D52G-5HacD2HnD-TC
# serial number = 8D150889BCC7
add mtu=1500 name=bridge1 protocol-mode=none
/interface eoip
add allow-fast-path=no local-address=192.168.3.2 mac-address=02:1E:B8:08:5E:22 mtu=1500 name=EOIP_Work remote-address=192.168.3.1 tunnel-id=0
/interface vlan
add interface=bridge1 name=VLAN_4_LAN vlan-id=4
add interface=bridge1 name=VLAN_6_GuestWifi vlan-id=6
add interface=bridge1 name=VLAN_7_KidsWifi vlan-id=7
add interface=bridge1 name=VLAN_10_VPN vlan-id=10
add interface=bridge1 name=VLAN_13_CCTV vlan-id=13
add interface=bridge1 name=VLAN_20_SmartHome vlan-id=20
add interface=bridge1 name=VLAN_99_Virgin vlan-id=99
set 0 vlan-mode=secure
set 1 default-vlan-id=20 vlan-mode=secure
set 2 default-vlan-id=20 vlan-mode=secure
set 3 default-vlan-id=20 vlan-mode=secure
set 4 default-vlan-id=20 vlan-mode=secure
set 5 vlan-mode=secure
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=Isolated
add name="Mobile Allowed"
/interface lte apn
set [ find default=yes ] passthrough-mac=auto
add authentication-types=wpa-psk,wpa2-psk management-protection=allowed mode=dynamic-keys name=Deli supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=ERL supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk management-protection=allowed mode=dynamic-keys name="Daves iPhone" supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="united kingdom" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge security-profile=Deli ssid=Deli station-roaming=enabled vlan-id=4 \
vlan-mode=use-tag wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country="united kingdom" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge security-profile=Deli ssid=Deli station-roaming=enabled vlan-id=4 \
add disabled=no keepalive-frames=disabled mac-address=CE:2D:E0:EB:1F:99 master-interface=wlan1 multicast-buffering=disabled name=wlan3 security-profile=ERL ssid=ERL station-roaming=enabled vlan-id=9 vlan-mode=use-tag wds-cost-range=0 \
wds-default-cost=0 wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=CE:2D:E0:EB:1F:9A master-interface=wlan2 multicast-buffering=disabled name=wlan4 security-profile=ERL ssid=ERL station-roaming=enabled vlan-id=9 vlan-mode=use-tag wds-cost-range=0 \
/ip hotspot profile
add name=Pool_LAN ranges=192.168.6.2-192.168.6.254
add name=Pool_SmartHome ranges=192.168.20.2-192.168.20.254
add name=Pool_CCTV ranges=192.168.4.2-192.168.4.10
add name=Pool_GuestWifi ranges=10.0.2.2-10.0.2.254
add name=Pool_KidsWifi ranges=10.0.10.2-10.0.10.254
add name=Pool_VPN ranges=192.168.5.2-192.168.5.254
add name=pool1 ranges=192.168.51.2-192.168.51.254
add name=openvpn ranges=192.168.52.1-192.168.52.3
add add-arp=yes address-pool=Pool_LAN disabled=no interface=VLAN_4_LAN name=DHCP_LAN
add add-arp=yes address-pool=Pool_KidsWifi disabled=no interface=VLAN_7_KidsWifi name=DHCP_KidsWifi
add add-arp=yes address-pool=Pool_SmartHome disabled=no interface=VLAN_20_SmartHome name=DHCP_SmartHome
add add-arp=yes address-pool=Pool_CCTV disabled=no interface=VLAN_13_CCTV name=DHCP_CCTV
add add-arp=yes address-pool=Pool_GuestWifi disabled=no interface=VLAN_6_GuestWifi name=DHCP_GuestWifi
add address-pool=Pool_VPN disabled=no interface=VLAN_10_VPN name=DHCP_10_VPN
/ppp profile
add name=Work remote-address=192.168.3.1 use-encryption=yes
/interface l2tp-client
add allow=mschap2 allow-fast-path=yes connect-to=**.**.**.** disabled=no keepalive-timeout=disabled name=Work profile=Work use-ipsec=yes user=************
/tool user-manager customer
set admin access=own-routers,own-users,own-profiles,own-limits,config-payment-gw
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
/interface bridge filter
add action=accept chain=input disabled=yes in-interface=EOIP_Work mac-protocol=vlan vlan-id=9
add action=accept chain=output disabled=yes mac-protocol=vlan out-interface=EOIP_Work vlan-id=9
add action=accept chain=forward disabled=yes in-interface=EOIP_Work mac-protocol=vlan vlan-id=9
add action=accept chain=forward disabled=yes mac-protocol=vlan out-interface=EOIP_Work vlan-id=9
add action=accept chain=input disabled=yes in-interface=EOIP_Work mac-protocol=vlan vlan-id=2
add action=accept chain=output disabled=yes mac-protocol=vlan out-interface=EOIP_Work vlan-id=2
add action=accept chain=forward disabled=yes in-interface=EOIP_Work mac-protocol=vlan vlan-id=2
add action=accept chain=forward disabled=yes mac-protocol=vlan out-interface=EOIP_Work vlan-id=2
add action=drop chain=input disabled=yes in-interface=EOIP_Work
add action=drop chain=output disabled=yes out-interface=EOIP_Work
add action=drop chain=forward disabled=yes out-interface=EOIP_Work
add action=drop chain=forward disabled=yes in-interface=EOIP_Work
add bridge=bridge1 interface=wlan3
add bridge=bridge1 interface=wlan4
add bridge=bridge1 interface=wlan2
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=EOIP_Work
add independent-learning=no ports=switch1-cpu,ether1 switch=switch1 vlan-id=10
add independent-learning=no ports=switch1-cpu,ether1 switch=switch1 vlan-id=9
add independent-learning=no ports=switch1-cpu,ether1 switch=switch1 vlan-id=98
add independent-learning=no ports=switch1-cpu,ether1 switch=switch1 vlan-id=6
add independent-learning=no ports=switch1-cpu,ether1 switch=switch1 vlan-id=7
add independent-learning=no ports=switch1-cpu,ether1,ether2,ether3,ether4,ether5 switch=switch1 vlan-id=20
add independent-learning=no ports=switch1-cpu,ether1 switch=switch1 vlan-id=13
add independent-learning=no ports=switch1-cpu,ether1 switch=switch1 vlan-id=4
add independent-learning=no ports=switch1-cpu,ether1 switch=switch1 vlan-id=2
add independent-learning=no ports=switch1-cpu,ether1 switch=switch1 vlan-id=99
add interface=VLAN_4_LAN list=LAN
add interface=VLAN_99_Virgin list=WAN
add interface=VLAN_20_SmartHome list=LAN
add interface=VLAN_13_CCTV list=LAN
add interface=EOIP_Work list=LAN
add interface=Work list=LAN
add interface=VLAN_6_GuestWifi list=LAN
add interface=VLAN_7_KidsWifi list=LAN
add interface=VLAN_10_VPN list=LAN
add interface=VLAN_6_GuestWifi list=Isolated
add interface=VLAN_7_KidsWifi list=Isolated
add interface=VLAN_10_VPN list=Isolated
add interface=VLAN_20_SmartHome list=Isolated
add interface=EOIP_Work list="Mobile Allowed"
add interface=Work list="Mobile Allowed"
add interface=VLAN_4_LAN list="Mobile Allowed"
add address=192.168.6.1/24 interface=VLAN_4_LAN network=192.168.6.0
add address=192.168.20.1/24 interface=VLAN_20_SmartHome network=192.168.20.0
add address=192.168.4.1/24 interface=VLAN_13_CCTV network=192.168.4.0
add address=10.0.2.1/24 interface=VLAN_6_GuestWifi network=10.0.2.0
add address=10.0.10.1/24 interface=VLAN_7_KidsWifi network=10.0.10.0
add address=192.168.5.1/24 interface=VLAN_10_VPN network=192.168.5.0
/ip dhcp-client
add disabled=no interface=VLAN_99_Virgin
/ip dhcp-server lease
add address=192.168.4.2 client-id=1:c0:56:e3:a2:80:32 comment="CCTV - Hikvision - DS-2CD2032-I - Front Right" mac-address=C0:56:E3:A2:80:32 server=DHCP_CCTV
add address=192.168.20.250 comment="SmartHome - Shelly - One - Hallway Light" mac-address=B4:E6:2D:55:EB:41 server=DHCP_SmartHome
add address=192.168.20.244 comment="SmartHome - Amazon - Echo - Kitchen" mac-address=00:71:47:3D:DA:FA server=DHCP_SmartHome
add address=192.168.20.253 comment="SmartHome - Shelly - One - Georges Socket" mac-address=3C:71:BF:2C:06:9D server=DHCP_SmartHome
add address=192.168.4.5 client-id=1:c0:56:e3:a2:7f:92 comment="CCTV - Hikvision - DS-2CD2032-I - Garden" mac-address=C0:56:E3:A2:7F:92 server=DHCP_CCTV
add address=192.168.4.3 client-id=1:c0:56:e3:a2:7e:f0 comment="CCTV - Hikvision - DS-2CD2032-I - Front Left" mac-address=C0:56:E3:A2:7E:F0 server=DHCP_CCTV
add address=192.168.20.252 comment="SmartHome - Shelly - One - Bathroom Light" mac-address=B4:E6:2D:55:E4:6D server=DHCP_SmartHome
add address=192.168.20.247 comment="SmartHome - Intesis - Mitsubishi Wifi - Charlies Bedroom" mac-address=CC:3F:1D:01:2C:1D server=DHCP_SmartHome
add address=192.168.20.251 comment="SmartHome - Shelly - One - Charlies Socket" mac-address=B4:E6:2D:55:5B:9B server=DHCP_SmartHome
add address=192.168.20.248 comment="SmartHome - Google - Nest Protect - Hallway" mac-address=18:B4:30:B6:9B:74 server=DHCP_SmartHome
add address=192.168.20.243 client-id=1:40:a2:db:b5:d5:4d comment="SmartHome - Amazon - Echo Show - Lounge" mac-address=40:A2:DB:B5:D5:4D server=DHCP_SmartHome
add address=192.168.6.4 client-id=1:0:8:9b:e8:74:bc comment="LAN - QNAP - NAS" mac-address=00:08:9B:E8:74:BC server=DHCP_LAN
add address=192.168.6.30 comment="LAN - Virgin - Master Bedroom" mac-address=88:71:B1:AA:CE:B4 server=DHCP_LAN
add address=255.255.0.3 block-access=yes client-id=1:44:0:49:8d:23:fb comment=Blocked mac-address=44:00:49:8D:23:FB server=DHCP_LAN
add address=192.168.6.31 comment="LAN - Virgin - Lounge" mac-address=88:71:B1:AA:D1:8C server=DHCP_LAN
add address=192.168.6.21 client-id=1:e4:e0:a6:a4:85:85 comment="LAN - Apple - iWatch - Jodie" mac-address=E4:E0:A6:A4:85:85 server=DHCP_LAN
add address=192.168.20.249 comment="SmartHome - Google - Nest Protect - Landing" mac-address=18:B4:30:B3:28:C9 server=DHCP_SmartHome
add address=192.168.6.20 client-id=1:f0:18:98:ec:86:db comment="LAN - Apple - iMac - Dave" mac-address=F0:18:98:EC:86:DB server=DHCP_LAN
add address=192.168.6.40 client-id=1:50:1a:c5:df:4:ad comment="LAN - Microsoft - XBox One - Charlie (Wifi)" mac-address=50:1A:C5:DF:04:AD server=DHCP_LAN
add address=192.168.6.24 client-id=1:dc:8:f:38:ee:5 comment="LAN - Apple - iPhone - Jodie" mac-address=DC:08:0F:38:EE:05 server=DHCP_LAN
add address=192.168.6.105 comment="LAN - Netgear - SG108Ev3 - Garage" mac-address=14:59:C0:54:DC:2D server=DHCP_LAN
add address=192.168.6.200 comment="intesis box - should be smarthome" mac-address=CC:3F:1D:01:2C:B1 server=DHCP_LAN
add address=192.168.6.25 client-id=1:74:9e:af:5b:85:39 comment="LAN - Apple - iPhone - Dave" mac-address=74:9E:AF:5B:85:39 server=DHCP_LAN
add address=10.0.10.2 client-id=1:fc:1d:43:85:5c:d9 comment="WifiKids - Apple - iPad - George" mac-address=FC:1D:43:85:5C:D9 server=DHCP_KidsWifi
add address=192.168.20.236 comment="SmartHome - Sonoff - POW_R2 - Swimming Pool" mac-address=80:7D:3A:32:B8:0B server=DHCP_SmartHome
add address=192.168.20.220 client-id=1:0:51:ed:f2:19:d7 comment="SmartHome - LG - TV - Kitchen" mac-address=00:51:ED:F2:19:D7 server=DHCP_SmartHome
add address=192.168.20.50 client-id=1:74:9e:af:5b:85:39 comment="SmartHome - Apple - iPhone - Dave" mac-address=74:9E:AF:5B:85:39 server=DHCP_SmartHome
add address=192.168.6.14 comment="LAN - Nintendo - Switch" mac-address=70:48:F7:61:3A:69 server=DHCP_LAN
add address=192.168.6.104 comment="LAN - Netgear - GS308E - Cupboard" mac-address=08:36:C9:0A:EE:B7 server=DHCP_LAN
add address=192.168.20.241 client-id=1:5c:41:5a:7f:27:a1 comment="SmartHome - Amazon - Echo Dot - Charlie" mac-address=5C:41:5A:7F:27:A1 server=DHCP_SmartHome
add address=192.168.20.242 client-id=1:cc:9e:a2:85:3c:36 comment="SmartHome - Amazon - Echo Dot - George" mac-address=CC:9E:A2:85:3C:36 server=DHCP_SmartHome
add address=192.168.20.245 comment="SmartHome - Amazon - Echo Dot - Master Bedroom" mac-address=F0:81:73:75:E8:64 server=DHCP_SmartHome
add address=255.255.0.2 block-access=yes client-id=1:5c:41:5a:7f:27:a1 comment=Blocked mac-address=5C:41:5A:7F:27:A1 server=DHCP_LAN
add address=255.255.0.1 block-access=yes client-id=1:cc:9e:a2:85:3c:36 comment=Blocked mac-address=CC:9E:A2:85:3C:36 server=DHCP_LAN
add address=192.168.20.235 comment="SmartHome - Drayton Wiser - Heating" mac-address=FC:FE:C2:02:F8:55 server=DHCP_SmartHome
add address=255.255.0.5 block-access=yes comment=Blocked mac-address=00:71:47:3D:DA:FA server=DHCP_LAN
add address=255.255.0.4 block-access=yes comment=Blocked mac-address=F0:81:73:75:E8:64 server=DHCP_LAN
add address=192.168.20.234 comment="SmartHome - LightwaveRf - LinkPlus" mac-address=74:0A:BC:31:0F:88 server=DHCP_SmartHome
add address=192.168.20.210 comment="SmartHome - Phillips Hue - Bridge - Master" mac-address=EC:B5:FA:0B:2F:15 server=DHCP_SmartHome
add address=192.168.20.212 comment="SmartHome - Phillips Hue - Bridge - Charlie" mac-address=EC:B5:FA:0B:20:B1 server=DHCP_SmartHome
add address=192.168.20.211 comment="SmartHome - Phillips Hue - Bridge - George" mac-address=00:17:88:67:76:51 server=DHCP_SmartHome
add address=192.168.6.106 client-id=1:78:d2:94:c2:1:57 comment="LAN - Netgear - GS105Ev2 - Lounge" mac-address=78:D2:94:C2:01:57 server=DHCP_LAN
add address=192.168.6.100 comment="LAN - Netgear - GS724T - Cupboard" mac-address=44:94:FC:9D:52:BE server=DHCP_LAN
add address=192.168.6.101 comment="LAN - Netgear - GS110TP - Cupboard" mac-address=78:D2:94:4F:3A:3C server=DHCP_LAN
add address=192.168.6.103 client-id=1:fc:ec:da:34:9d:53 comment="LAN - Netgear - GS105 - Charlies Bedroom" mac-address=FC:EC:DA:34:9D:53 server=DHCP_LAN
add address=192.168.6.41 client-id=1:50:1a:c5:df:4:af comment="LAN - Microsoft - XBox One - Charlie (LAN)" mac-address=50:1A:C5:DF:04:AF server=DHCP_LAN
add address=192.168.6.102 client-id=1:78:d2:94:c2:1:8e comment="LAN - Netgear - GS105Ev2 - Lounge" mac-address=78:D2:94:C2:01:8E server=DHCP_LAN
add address=192.168.20.49 client-id=1:d0:c5:d3:45:46:d9 comment="SmartHome - Hikvision - CS-DB1" mac-address=D0:C5:D3:45:46:D9 server=DHCP_SmartHome
add address=192.168.20.43 client-id=1:40:16:3b:5a:73:42 comment="SmartHome - Samsung - Lounge TV" mac-address=40:16:3B:5A:73:42 server=DHCP_SmartHome
add address=10.0.2.0/24 dns-server=10.0.2.1 gateway=10.0.2.1 netmask=24
add address=10.0.10.0/24 dns-server=10.0.10.1 gateway=10.0.10.1 netmask=24
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1 netmask=24
add address=192.168.4.0/24 dns-server=192.168.4.1 gateway=192.168.4.1 netmask=24
add address=192.168.5.0/24 dns-server=192.168.5.1 gateway=192.168.5.1 netmask=24
add address=192.168.6.0/24 dns-server=192.168.6.1 gateway=192.168.6.1 netmask=24
add address=192.168.20.0/24 dns-server=192.168.20.1 gateway=192.168.20.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=192.168.6.0/24 list=LAN
add address=192.168.23.0/24 list=LAN
add address=192.168.4.0/24 list=LAN
add address=192.168.3.0/24 list=LAN
add address=192.168.20.0/24 list=LAN
add address=10.0.2.0/24 list=LAN
add address=10.0.10.0/24 list=LAN
add address=192.168.5.0/24 list=LAN
add address=192.168.6.0/24 list=4_LAN
add address=192.168.23.0/24 list=9_Work
add address=192.168.4.0/24 list=13_CCTV
add address=192.168.3.0/24 list=0_WorkVPN
add address=192.168.20.0/24 list=20_SmartHome
add address=10.0.2.0/24 list=6_GuestWifi
add address=10.0.10.0/24 list=7_KidsWifi
add address=192.168.5.0/24 list=10_VPN
add address=192.168.2.0/24 list=LAN
add address=192.168.2.0/24 list=0_Canvey
add action=accept chain=forward comment="SmartHome to OpenHab" dst-address=192.168.6.4 in-interface=VLAN_20_SmartHome out-interface=VLAN_4_LAN
add action=accept chain=forward in-interface=VLAN_4_LAN out-interface=VLAN_20_SmartHome src-address=192.168.6.4
add action=drop chain=forward comment="Isolated LANS" in-interface-list=Isolated out-interface-list=Isolated src-address-list=""
add action=accept chain=input comment=VPN dst-port=500,1701,4500 in-interface-list=WAN protocol=udp
add action=accept chain=output out-interface-list=WAN protocol=udp src-port=500,1701,4500
add action=accept chain=output out-interface-list=WAN protocol=ipsec-esp
add action=accept chain=output out-interface=Work protocol=gre
add action=accept chain=forward comment="Mobile Broadband" disabled=yes dst-address=192.168.6.20 in-interface=wlan1 out-interface=VLAN_4_LAN
add action=accept chain=forward disabled=yes in-interface=VLAN_4_LAN out-interface=wlan1 src-address=192.168.6.20
add action=drop chain=forward disabled=yes in-interface=wlan1
add action=drop chain=forward disabled=yes out-interface=wlan1
add action=log chain=output disabled=yes log=yes log-prefix="OUTPUT MOBILE BROADBAND" out-interface=wlan1
add action=log chain=input disabled=yes in-interface=wlan1 log=yes log-prefix="OUTPUT MOBILE BROADBAND"
add action=accept chain=output comment="Allow to LAN Addresses - ie ICMP, TCP ACK" dst-address-list=LAN out-interface-list=LAN src-address-list=LAN
add action=accept chain=input dst-address-list=LAN in-interface-list=LAN src-address-list=LAN
add action=accept chain=forward dst-address-list=LAN in-interface-list=LAN out-interface-list=LAN src-address-list=LAN
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=log chain=input disabled=yes log=yes
add action=log chain=forward disabled=yes
/ip firewall service-port
set ftp disabled=yes
add distance=1 dst-address=192.168.2.0/24 gateway=Work
add distance=1 dst-address=192.168.23.0/24 gateway=Work
/ip service
set telnet disabled=yes
set www port=28000
set ssh disabled=yes
set winbox port=28001
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=VLAN_4_LAN type=internal
add interface=VLAN_99_Virgin type=external
/system clock
set time-zone-name=Europe/London
/tool graphing interface
add interface=wlan1
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
#error exporting /tool user-manager database
[admin@MikroTik] >
