Bridge with webproxy
good day,
i have a RB532 unit and i am using eth2 and eth3 as bridge for bandwidth management purposes, i was wondering if there is a way to capture port 80 traffic and redirect it to the webproxy? ive been searching in the forum but i could not find a solution…
thank you
Transparent-proxy configuration example is described in documentation, when local network users requests transparently redirected to router’s proxy, using NAT rules,
http://www.mikrotik.com/docs/ros/2.9/ip/webproxy.content#7.53.7
sir,
i’ve have used this transparent proxy for NAT implementation, but im not using nat for local users hence the bridge mode. would the webproxy still be possible?
i have also tried your suggestion, it didn’t work.
anymore suggestions???
thank you
