Bridge WLAN to Ethernet ports (RB951Ui-2nD)
Hi MikroTik forum members!
I’m new on the block, but willing to learn!
I have a number of Ethernet-only devices that need Internet access. I have a RouterBOARD RB951Ui-2nD (hAP series) to solve the problem. I would like to create a bridge to the local Wi-Fi network and make Internet access available to all five Ethernet ports on the router.
I’ve set up the bridge and connected to a network (with the correct security profile) through wireless. I have a default gateway (192.168.43.1) set up that I got from using the Windows command prompt to determine the network default gateway. The bridge has, I think, a suitable address (192.168.43.5/24). The ping test fails, so I’ve clearly done something incorrectly.
I’ve attached the support output file, if that provides any clarity. Thanks for your time.
Sincerely
sparkbee
supout.zip (371 KB)
Post a hand drawn schematic on how the 951 is wired to your router and rest of the network, otherwise it will be difficult to help.
Hi pukkita
RouterOS version: 6.38.5 (updated today)
I’ve attached screenshots that show the information I’ve entered. Also, see goal.pdf (also attached) for what I am trying to do.
Right now, I’m using an Android smartphone hotspot as the test WLAN to connect to.
I looked at the Firewall settings (screenshot attached) and saw some strange things there. Not too sure how to approach that.
Sincerely
sparkbee
screenshots.zip (193 KB)
goal.pdf (54 KB)
I made contact with MikroTik Support, it turns out there is a pre-set setup for this kind of network connection. It is called CPE (Customer Premises Equipment) and can be set up via the Quickset menu (available in Winbox and Webfig; I used Winbox). You can thus connect Ethernet-only devices to a WLAN by bridging with the 951 in the CPE mode.
Useful reading on MikroTik modes: http://forum.mikrotik.com/t/simple-types-cpe-wisp-ptp-bridge/79874/1
Thanks to Antons from MikroTik Support for suggesting the use of the CPE mode.
