I wolud like to build something like bridge, but i’m not sure how to do it. Could you help me please?
InternetRouterAPCisco(wlan1MIKROTIKwlan2)<>>> wireless clients
So, Mikrotik shoud be client on Wlan1 to connect with APCisco, but 2nd Mikrotik Wlan should be Aceess Point.
How to do it? Is it possible with MT??
No one know how to do it??
Station does not support bridging, Cisco AP should support WDS to accompish your scenario.
If AP supports WDS than establish WDS link between AP and MikroTik, bridge wlan1,wds and wlan2 (AP on the MikroTik).
If AP does not support WDS, than NAT should help you, MikroTik router will not act as bridge. Clients will have private addresses, and use wlan1 address as outgoing address.
Thank you.
So - it’s acceptable solution for me. If i have undrestood you, it is possibility to run wlan1 as station, wlan 2 as AP and enable routing between wlan1<>wlan2 ?? Am i right?
wlan1 has to be station-wds mode and your Cisco must have WDS configured if you want it to be a bridge.
No, i have no WDS mode. But i would like to implement your 2nd solution. That mean wlan1-station mode, wlan2-bridge/AP mode. Should it work good?
Second scenario should work, but MikroTik router will not act as bridge.
You will need to set private subnet to clients (e.g. 192.168.0.0/24) and enable masquerading with out-interface=wireless_station.
