I have the following scenario :
LAN ----> RB2011 --------------------> ISP ROUTER
SAME-----> RB751 -------------------/
LAN
In order to do that I have bridged the RB2011 Lan With the RB751 Lan using an PPTP Tunnel, and for the Lan all works just fine.
The problem I find is that when a Client conects to the RB751, it gets the DHCP for the RB2011 which of course sets the Gateway as the RB2011 so when it goes out to Internet it has to go through the PPTP tunnel and then back to the ISP Router.
What I want to know is if there is a way to set the client’s gateway as the router that’s connected to.
