Dear,
I need to migrate from a bridged wireless network to a routed wireless network have you any guidelines to make the network reconfiguration?
Regards
The best way is to change the ip’s on router boards and access points, in order for routing to be able to work. Then activate routing rip on all your routers. This will sort your router paths automatically. To see if it is running go to ip routes. Should be many routes, getting more as you change router boards. As soon as this is done. Disable bridge. If done correctly, every thing should keep on running. Very easy.
Biggest thing is the ip’s make a nice exel spread sheet.
i aldeady know it.
I need configuration guidelines - examples.
Access point (wlan1 wlan2 ethernet) routes and firewall configurations
edge router configuration
ecc.
For an overview on how you should approach it, go through Tiktube.com as I recall there was a presentation about this during one of the Poland MUMs, not sure which one though!
If you need specifics, please hire one of us here ![]()
Dear,
I’ ve not founded the mum presentation,
Can you give me an hand to make this migration ?
Regards
sure can help you with it.. send me a private message with your e-mail or Skype address
i’m sorry but i’m not able to send private message in this forum, i do not have private messages link
[offtop]
omg! they switched them off again =(
Normis, please, enable PMs =)
[/offtop]
Dear,
i’ve done the migration successfull..
using ospf and mpls for centralized pppoe.
it works very very well
did you use VPLS?
yes, i use ospf, mpls , vpls
rpengineering,
What’s your mtu?
I used some uplinks ubnt.
ubnt’s support MTU 1518
it is not work on our network with ubnts, I think
Cain i have ur email id…i also want to migrate bridge network to router network. Can u help me with that.
Dear,
i can help you but
i’ve mp disabled please use my skype id alexrpeng
Regards
rpengineering,
What’s your mtu?
ubnt’s support MTU 1518it is not work on our network with ubnts, I think
My mtu is 1504
