at the company I’m working for we want to create an VLAN-setup with 12 separate vlan-networks for guests, it-administration, production, telephony, the office and so on.
We have a RouterBoard 1100AHx4 (6.43.7). This is connected to the provider-router on ether1. This connection works (I can ping servers outside).
We have some switches (d-link, managed), where the vlan-id’s are set and are working internally. the first switch from the router-side is connected on router-port ether6 with vlan-ids 1 and 10 (it-network, telephony)
Problem: only one of the both vlans is working correctly (depending on configuration, tested by ping on known hosts inside the vlan).
What I added:
bridge1, without vlan-filtering.
vlan1, with id=1 and interface=bridge1
vlan10, with id=10 and interface=bridge1
bridge1 ports:
→ vlan1 (pvid=1), vlan10 (pvid=10) and ether6 (pvid=1)
bridge1 vlans:
→ vlan-id 1 with tagged ether6 and untagged vlan1 and bridge1
→ vlan-id 10 with tagged ether6 and untagged vlan10 and bridge1
ip/adresses:
bridge1: 10.10.10.12/8 network 10.0.0.0
bridge1: 192.168.10.1/14 network 192.168.10.0
ether1: 102.168.200.4/24 network 192.168.200.0
ip/routes:
0.0.0.0/0 gateway 192.168.200.6 (via ether1) → works
dynamic: 10.0.0.0/8 gateway bridge1
dynamic: 192.168.10.0/24 gateway bridge1
dynamic: 192.168.200.0/24 gateway ether1
now I turned vlan-filtering on bridge1 on, with pvid=1
→ can reach anything in 192.168.200.0/24 (“outside”)
→ can reach anything in 10.0.0.0/8
→ can’t reach 192.168.10.0/24
changed pvid=10
→ now I can reach 192.168.10.0/24, but 10.0.0.0/8 no longer.
turned vlan-filtering off: behaves like first case.
this is the actual configuration:
/interface bridge print
0 R name="bridge1" mtu=auto actual-mtu=1500 l2mtu=1592 arp=enabled arp-timeout=auto mac-address=CC:2D:E0:DC:2B:62 protocol-mode=none
fast-forward=no igmp-snooping=no auto-mac=yes ageing-time=5m vlan-filtering=yes ether-type=0x8100 pvid=1 frame-types=admit-all
ingress-filtering=no dhcp-snooping=no
/interface vlan print
# NAME MTU ARP VLAN-ID INTERFACE
0 R IT-Netz (VLAN 1) 1500 enabled 1 bridge1
1 R Telefonie (VLAN 10) 1500 enabled 10 bridge1
/interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
# INTERFACE BRIDGE HW PVID PRIORITY PATH-COST INTERNAL-PATH-COST HORIZON
0 Telefonie (VLAN 10) bridge1 10 0x80 10 10 none
1 IT-Netz (VLAN 1) bridge1 1 0x80 10 10 none
2 ether6 bridge1 yes 1 0x80 10 10 none
/interface bridge vlan print
Flags: X - disabled, D - dynamic
# BRIDGE VLAN-IDS CURRENT-TAGGED CURRENT-UNTAGGED
0 bridge1 10 ether6 bridge1
Telefonie (VLAN 10)
1 bridge1 1 ether6 bridge1
IT-Netz (VLAN 1)
/ip address print
# ADDRESS NETWORK INTERFACE
0 192.168.200.4/24 192.168.200.0 ether1
1 10.10.10.12/8 10.0.0.0 bridge1
2 192.168.10.1/24 192.168.10.0 bridge1
/ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 192.168.200.6 1
1 ADC 10.0.0.0/8 10.10.10.12 bridge1 0
2 ADC 192.168.10.0/24 192.168.10.1 bridge1 0
3 ADC 192.168.200.0/24 192.168.200.4 ether1 0
I read the wiki-pages on bridging, vlan and so on and some other examples/problem-descriptions on this forum.
But I get stuck here…
simple question (hopefully): where am I thinking in the wrong way?
Thanks for your help,
Christoph
