bridging 2 mikrotik boards
i have two mikrotik boards set as APs. one is using v4 so i can connect nanostationm5 clients.
i want to bridge these two using ether 2 on both boards. is this possible.
Why do you want to do this?
I assume both boards are running down to the same switch via ether1 and you have WLan1 bridged to ether1. Is that correct?
Of course you could bridge ether1 ether2 and wlan1 on both boards but you will have a loop unless you disconnect one of the boards from the switch downstairs.
i have bridge ether 1,2 with wlan but i have not yet connected them on a switch.with the switch its ok i have tried it but i just wanted to know if bridging form the enclosure would do the same.
Yes, of course. Why not?
Plug it in, configure correctly, and enjoy.
thanks you people
