Bridging 2 networks using RB112 r52
How can i do this?
i ve tryied this
http://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks
but the client never connects
Thats the only why for doing that?
why i cannot set the 2 wlan0 as bridge and then in both rb112 create a bridge eth1-wlan1
is there any guide besides that doc?
Thank you.
you can set both wireless interface as mode=bridge, but WDS will be required to establish connection between them.
mode=bridge is the same as ap-bridge, the difference between them that only one client is able to connect to ‘bridge’. but ‘ap-bridge’ for point to multipoint communications. Connection between two APs is possbile only with WDS.
Wireless documetation,
http://www.mikrotik.com/docs/ros/2.9/interface/wireless
Wiki examples should work fine, if you have configured all settings correctly.
when you say connection between 2 ap you mean, both can connect each other?
the first example in this link http://www.mikrotik.com/docs/ros/2.9/interface/wireless
shows how 2 ap can connect eachother, using mode bridge and station ap.
Example shows how to connect mode=ap-bridge and mode=station (there is no such option as station AP).
Stations might connect to AP without any problems.
and why in the wiki doc, there is no configuration about the access list and the connect list?
Wiki is a place where users of MikroTik share information, examples, howtos and ideas with each other. This is not an official supported MikroTik manual, but rather a community page that everyone can edit.
You can add configuration example about Access List and Connect List to the wiki page.
Acces List and connect list pretty well described in the documentation.
I see my wlan with no R in the winbox wileress interface table
R means suning I guess
I should do
interface wireless wds add?
it works,
I had to reset both routerboards
I found some isues,
1 If i press align monitor on the bridge, the ethernet connection dies :open_mouth:
2 winbox isnt work fine, i made changes and notting happens, console is the best, I wish a method to do telnet using mac
Im gonna set a point to point link over 20km I got 2.4 ghz antennas, which band i should use and wich configuration will work better?
2.4g/b turbo nstream?
Thank you all
use snooper tool to see what frequencies are occupied, use the one that is free of interference.
if i use the snooper tool or scan mode or alignment
my interface ether1 dies,
this happen on the equipment configure as bridge with wds
is this a bug? its ok?
i dont understand whay if i change the mode on wlan1 ether1 desnt respond any more for a few seconds 30 60s
to use any other mode I must disable the bridge, and it works ok
