Bridging 2 vlans over routed ports ?
List,
Got a RB500
Eth Port 1 is WAN
Erh Port 2 is LAN
Im currently routing,
But I got a special situation where vlan tagged packets needs to be bridged over this 2 ports…
VID 333 traffic needs to pass trough from the WAN over to the LAN, any ideas on how to do this without breaking routing for untagged packets ?
Gino
Not sure if it can be done keeping the same VLANID, but create a VLAN on Eth1 and join it up with the existing VLAN, create a new VLAN on Eth2, and add the two VLANs into a bridge?
Should work… I’m not however sure how MT will handle it if both VLANs sit with the same ID..
