Bridging an external Tranzeo AP with DHCP from RB435
Set up a simple 435 to take advantage of the onboard power and that works fine hardwired, but it will not bridge DHCP to an external Tranzeo 510 mesh gateway that is using Centralized DHCP with a fixed IP on the gateway side within the IP range. This works off of a Cisco router, but what am I missing in the mix on programming the routerboard?
