Ok… been trying to get this working.. I have a Cisco switch with multiple vlans trunked through a port to a SXT. In the SXT I want each vlan to be bridged to the wireless device. Basically I want all the vlans to be able to communicate across the wireless link as if the SXT’s ethernet and wireless interface were bridged (like it is now). But I want the vlans as each client is a vlan that we want to control qos (throttleing ) for in a multi tenent building. Currently I have the Vlans set up under the ether1 interface and bridged to the the Wlan1 interface (ether1 is NOT in this bridge)… but I can’t see the VLAN traffic. Any help would be appricated
in bridge settings set use IP firewall and then check also, “Use IP Firewall For VLAN”
then you will be able to use QoS for VLAN traffic.
Ok… but on the wireless side it has to be untagged… and I’m not seeing the Vlan ID’s coming in (at least there’s nothing on torch)
