Bridging Ethernet with VLan's
Hi All,
I was wondering if anyone knows of a way to bridge a Ethernet port that has to a wireless PTP link and have any vlan’s that are being provided by whatever is plugged into the Ethernet port spit out the other end of the wireless PTP link without having to create the vlan’s on the ROS box? I need to transparent bridge this Ethernet port over wireless as a backup link and need STP running on it but the Ethernet port also has VLan’s on it
Cheers
additional configuration is not required, just bridge ethernet with wireless. Vlan tags will be forwarded.
Hmmm, Not working in the Lab
I have Router A, It has a VLAN 100 on ether1 this plugs into Router B ether 1 which is bridged to ether 2 - No Vlan’s setup , ether 2 connects to ether 1 on Router C, I then add’s VLAN 100 on ether1 on Router C. Router C can’t talk to Router A on VLAN
