bridging firewall with each port restricted to 1 public IP
We’re looking to setup a mikrotik as a bridging firewall and we’re starting off by trying this on a 750G.
I’ve the router setup on test range 172.16.154.1/24
I’ve port 1 as the gateway
port 2 as the management network
port 4 as 172.16.254.10
port 5 as 172.16.254.11
There is a bridge called no-nat connecting port 1,4,5 with the firewall on.
We want to isolate all traffic between ports other than allowed with the firewall. Allow all outbound connections from the “local” ports. Then add some inbound rules to allow certain traffic in to specified IP’s. Currently there is just 1 inbound rule to allow web traffic on port 80 to .11
We also want to block all traffic on port 4 and 5 not from their allocated IP.
Below is the config we’re using. Does this make sense or are we overly complicating things? It seems to work although it seems that most of the traffic goes through the established and related rules.
# jan/18/2013 13:39:27 by RouterOS 6.0rc6
add l2mtu=1598 name=no-nat
set 2 master-port=ether2-master-local
/ip neighbor discovery
set ether1-gateway discover=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add address-pool=default-dhcp disabled=no interface=ether2-master-local name=\
    default
add bridge=no-nat interface=ether4-master
add bridge=no-nat interface=ether5-master
add bridge=no-nat interface=ether1-gateway
/interface bridge settings
set use-ip-firewall=yes
add address=192.168.88.1/24 comment="default configuration" interface=\
    ether2-master-local network=192.168.88.0
add address=172.16.254.1/24 interface=no-nat network=172.16.254.0
add address=192.168.88.0/24 comment="default configuration" dns-server=\
    192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes max-udp-packet-size=512 servers=172.16.1.1
/ip dns static
add address=192.168.88.1 name=router
add chain=forward comment="Allow all out on eth1 gw" out-bridge-port=\
    ether1-gateway out-interface=no-nat
    "block all traffic from bridge port 4 not on .10" in-bridge-port=\
    ether4-master src-address=!172.16.254.10
    "block all traffic from port 5 not on ,11" in-bridge-port=ether5-master \
    src-address=!172.16.254.11
add chain=input comment="default configuration" disabled=yes in-interface=\
    ether1-gateway protocol=icmp
add chain=input comment="default configuration" connection-state=established \
    in-bridge-port=ether1-gateway in-interface=no-nat
add chain=input comment="default configuration" connection-state=related \
add chain=forward comment="echo reply" icmp-options=0:0 protocol=icmp
add chain=forward comment="Allow all established traffic to bridge" \
    connection-state=established in-interface=no-nat
add chain=forward comment="Allow all related traffic to bridge" \
    connection-state=related in-interface=no-nat
add chain=forward comment="allow web traffic to .11" disabled=yes \
    dst-address=172.16.254.11 dst-port=80 protocol=tcp
add action=reject chain=forward comment=\
    "block all bridge traffic between ports not already allowed" \
    in-bridge-port=!ether1-gateway in-interface=no-nat out-bridge-port=\
    !ether1-gateway out-interface=no-nat reject-with=icmp-host-prohibited
    "block anything in through eth1 gw not already allowed" in-bridge-port=\
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=ether1-gateway to-addresses=0.0.0.0 !to-ports
/ip proxy
set max-cache-size=none
/queue interface
set ether1-gateway queue=ethernet-default
set ether2-master-local queue=ethernet-default
set ether3-slave-local queue=ethernet-default
set ether4-master queue=ethernet-default
set ether5-master queue=ethernet-default
/system clock
set time-zone-name=Europe/London
/tool mac-server
add disabled=no interface=ether2-master-local
add disabled=no interface=ether3-slave-local
add disabled=no interface=ether4-master
add disabled=no interface=ether5-master
/tool mac-server mac-winbox
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-master
add interface=ether5-master
