I am getting a little frustrated on what should be a simple setup (note - I use Graphical WinBox setup ONLY because I am simple!).
I Just cannot get internal routing between the two switch groups (ETH01-05 on switch_1; ETH06-10 on switch_2) ETH01 cannot talk to ETH06 etc.
I know that there are two physical (Atheros) switches in this unit and I SHOULD be able to Bridge between them.
Currently I am resorting to a physical cable between ETH05 and ETH06. I would like to remove the cable! (and gain a gigabit port back)
I have:
my RB2011 ETH01 connected to my home router and using the home router DHCP.
an IP address assigned to ETH02 as static so I can access it from my connected PC.
ETH01 to ETH05 in a port list called LAN_GB
ETH06 to ETH10 in a port list called LAN_MB
list LAN_GB attached to bridge_GB
list LAN_MB attached to bridge_MB
It should be as simple as - remove patch cable, attach list LAN_MB to bridge_GB - This Does Not Work.
Pulling my hair out here.
Any Ideas?
