haw can brodcast trafik pasthry router?
sory mai english owfol mai I ask on Rusian?
Broadcast traffic can pass through the router if you will bridge two interfaces together. And yes, you may ask in Russian ![]()
ok.
- Äåëàåì 1 ìàøèíó ñ 4 ñåòåâûìè 3êîì. p166-p600 64ram
1-ñåòåâàÿ 192.168.1.250
2-ñåòåâàÿ 192.168.2.250
3-áðèäæ ðàçðåøîí òîêà IP âñ¸ îñòàëüíîå çàïðåùåíî.
4-áðèäæ ðàçðåøîí òîêà IP âñ¸ îñòàëüíîå çàïðåùåíî.
1 è 3 ñåòåâûå âîòêíóòû â ñâè÷ 1-âîãî ñåãìåíòà
2 è 4 ñåòåâûå âîòêíóòû â ñâè÷ 2-âîãî ñåãìåíòà
íà 3 è 4 ñåòåâîé ARP âûêëþ÷åí. íà Áðèäæå àðï âûêëþ÷åí.
(òåîðåòè÷åñêè ÷åëîâåê ïîìåíÿâ àäðåñ â ïåðâîì ñåãìåíòå ñ 192,168,1,10 íà 192,168,2,10 íåïîëó÷èò íè÷åãî èç 2-îãî ñåãìåíòà)
òåïåðü ñìîòðèì êàê ðàáîòàåò.
Øèðîêîâåùàòåëüíûå ïàêåòû íà 255,255,255,255 è 192,168,1,255 è 192,168,2,255 âèäíû âåçäå.
ñòàâèì ïðàâèëî â Ôàåðâîëå äðèäæà è îòñåêàåì âñå 192,168,1,255 è 192,168,2,255.
îê
ðàáîòàåò. âñå êëàñíî.
À òåïåðü ïðîáëåìà.
â íåçàâèñèìîñòè îò êîìüïüþòåðà (ïðîáîâîëîñü 6 ðàçëè÷íûõ êîíôèãóðàöèé)
ìàøèíà çàâèñàåò - âûäîâàÿ ëèáî Êåðíåë ïàíèê ëèáî Kernel BUG on br_netfilter.c:101!
Ïðîáîâàëàñü äðåâíÿÿ âåðñèÿ 2.7.÷òîòî è 2.8.÷òîòî è 2.9á16
åäèíñòâåííîå ÷òî ïåðâûå 2 çàâèñàþò à 2.9.. ïåðåãðóæàåòñÿ.
Íà âîïðîñ çà÷åì. õî÷åòñÿ çäåëàòü ÷òîáû ÷åðåç ìàðøðóòèçàòîð ïåðåáåðàëèñü UDP ïàêåòû äëÿ èãð (ïðè ïîèñêå ñåðâåðà èãðà ðàññûëàåò ïàêåòû 255,255,255,255:27017)
ñòàáèëüíûé âûëåò íàáëèäàåòñÿ â òå÷åíèè íåäåëè 3-4 ðàçà.
íî ïðè âêëþ÷åíèè áðîäêàñòîâîãî ðàäèî 316êèëîáèò/ñ ìàøèíà âûëåòàåò ñðàçóæå.
âîïðîñ ìîæíî êàêòî ïðèäóìàòü ÷òîáû ïðîáðàñûâàòü ýòîò íåñ÷àñòíûé ïàêåò äëÿ òîãî ÷òîáû ìîæíî áûëî âèäåòü ñåðâåð ïî èãðå â äðóãîì ñåãìåíòå.
âðîäå âñ¸..
Ñïàñèáî.
But posting in Russian will also assure there are not many people out there who could help out with an answer… ![]()
of course you may, but the most people here talk english. anyway - as I don’t know the answer to your questions, I guess it leaves only eugene and lastguru ![]()
You should send support-output file from the router and the exact command to launch that broadcast radio together with this description to support@mikrotik.com
Êàæåòñÿ íàøîë ïðè÷èíó.
Äî ýòîãî èñïîëüçîâàëèñü ñåòåâûå íà ÷èïå 8139D è áûëà ýòà ïðîáëåìà.
Ïîïðîáëâàë ñåòåâóþ íà 8139C âðîäèáû ñòàëî ñòàáèëüíî.
Ìîæåò ýòî è åñòü ïðîáëåìà ? âîçìîæíî ëè òîêàå?
Yup, the ‘D’ revision is not supported at all.
