in Previous Post :
I Can Connect Directly to Station1(Direct1) , Can " MAC Telnet " to Station 2 From Station1 , Can Setup No Problem ..
Now ⦠!!?
All My Devices is MikroTik
in This Solution , Station1 is Connected to NET and Can Ping 4.2.2.4 , Station2 Routed to Station1 But Not Have NET and Canāt Ping The 4.2.2.4 .
i Canāt Fix This
i Think Problem is This ⦠!
MikroTik hor = My PtP in Bridge Station , ICT3 Connected to MiktoTik hor.
ICT1 is Hotspot in Station1.
G_ICT2 is PtP Connected to ICT2.
Station 1 :
/interface wireless print :
0 name="ICT 1" mtu=1500 mac-address=00:15:6D:65:2C:7F arp=enabled
interface-type=Atheros AR5413 mode=ap-bridge ssid="ICT 1"
frequency=2462 band=2.4ghz-b scan-list=default antenna-mode=ant-a
wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
compression=no
1 R name="ICT 2" mtu=1500 mac-address=00:15:6D:65:DD:B4 arp=enabled
interface-type=Atheros AR5413 mode=ap-bridge ssid="ICT 2"
frequency=5805 band=5ghz scan-list=default antenna-mode=ant-a
compression=no
2 R name="[color=#FF00BF]ICT 3[/color]" mtu=1500 mac-address=00:15:6D:65:DD:B9 arp=enabled
interface-type=Atheros AR5413 mode=station ssid="[color=#FF00BF]MikroTik hor[/color]"
frequency=5745 band=5ghz scan-list=default antenna-mode=ant-a
-- [Q quit|D dump|down]
/ip address print :
# ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.9.2/24 192.168.9.0 192.168.9.255 ICT 3
1 ;;; hotspot network
172.16.16.1/24 172.16.16.0 172.16.16.255 ICT 1
2 192.168.8.1/24 192.168.8.0 192.168.8.255 ICT 2
/ip route print :
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 192.168.9.1 1
1 ADC 172.16.16.0/24 172.16.16.1 hotspot_bridge 0
2 ADC 192.168.8.0/24 192.168.8.1 ICT 2 0
3 ADC 192.168.9.0/24 192.168.9.2 ICT 3 0
/interface bridge print :
0 R name="bridge1" mtu=1500 l2mtu=65535 arp=enabled
mac-address=00:00:00:00:00:00 protocol-mode=none priority=0x8000
auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s
forward-delay=15s transmit-hold-count=6 ageing-time=5m
1 R name="hotspot_bridge" mtu=1500 l2mtu=65535 arp=enabled
/interface bridge port print :
0 I ether1 bridge1 0x80 10 none
1 I ICT 1 hotspot_bridge 0x80 10 none
Station 2 :
0 R name="[color=#FF0080]G_ICT 1[/color]" mtu=1500 mac-address=00:15:6D:65:DD:AC arp=enabled
interface-type=Atheros AR5413 mode=station ssid="[color=#FF00BF]ICT 2[/color]"
compression=no
1 name="G_ICT 2" mtu=1500 mac-address=00:15:6D:65:DD:BA arp=enabled
interface-type=Atheros AR5413 mode=station ssid="G_ICT2"
compression=no
/ip address print :
0 192.168.8.2/24 192.168.8.0 192.168.8.255 G_ICT 1
/ip route Print :
# DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE
0 A S 0.0.0.0/0 reachable 192.168.8.1 1 G_ICT 1
1 ADC 192.168.8.0/24 192.168.8.2 0 G_ICT 1
/interface bridge Print (empty) :
/interface bridge port Print (empty) :
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
