I am trying to setup a simple test bridge between two RB532’s. I have Comp A connected directly to RB A Ether1, RB A Ether3 connected with a crossover to RB B Ether3 and RB B Ether1 Connected to Comp B.
I have a bridge established using EOIP tunnels. I can see the remote Mac address on RB B from RB A in the hosts table under the bridge tab. I can MAC ping the remote mac address, but I can not IP ping it.
I followed the docs and the only problem that I have is when I get to forward-protocols under the bridge port setup. It says command not found. I type “?” and I don’t see it listed. I’m using the level 3 (ISP) version of the software. Also it’s ver 2.9.4.
Any help will be appreciated.
David
