Bridging SSID to one VLAN on a trunk
I’m setting up a network where my Mikrotik will have two network connections plugged into it, both of which will be trunks containing the same 3 VLAN’s.
As I need an AP in the space where the Mikrotik will be, I thought I should use the built in function instead of buying another device. The tricky bit seems to be that I want to bridge the traffic from the WLAN with one of the VLAN’s that’s going down each trunk.
I can’t see a way to bridge the WLAN to the VLAN I’ve set up under the Switch config, is there a way of doing that?
My optimal config would end up having two SSID’s, each bridged to a different VLAN.
Bits of the config I think are relevant:
/interface wireless
set 0 band=2ghz-b/g/n disabled=no distance=indoors ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 ssid=BDX wireless-protocol=802.11
set 0 name=ether1-trunk
set 4 name=ether5-trunk
set 0 vlan-mode=secure
set 4 vlan-mode=secure
add independent-learning=no ports=ether1-trunk,ether5-trunk switch=switch1 vlan-id=1
add independent-learning=no ports=ether1-trunk,ether5-trunk switch=switch1 vlan-id=2
add independent-learning=no ports=ether1-trunk,ether5-trunk switch=switch1 vlan-id=10
I come from the Cisco side of the networking world, so if there’s any resources out there for learning RouterOS relating the functions and structure to IOS that would help me greatly.
In your switch config add the necessary VLANs to the CPU port. You want the VLANs tagged at this point so use the same settings as for trunks. Then add VLAN interfaces to the to the port that RouterOS uses to communicate with the switch (master port). Now bridge each VLAN interface to the relevant WLAN or VAP interface.
