hello,
please i need to bridge 2 interface ether1 and wds1 without using the bridge feature in mikrotik
is there is any way ??
regards
hello,
regards
Greetings!
If you want to connect two localnets on two routers with wireless without using WDS or bridges:
http://forum.mikrotik.com/t/ip-setup-on-two-wds-ap/25763/1
Look at the last post by SurferTim. Just set up the radios as you like in the modes specified, and the entries I list are the minimum. If that is not what you are looking for, if you could be a bit more specific.
