Broadcom NetXtreme Gigabit
Version 2.9 supports network cards Broadcom NetXtreme Gigabit Ethernet?
/sys resou pci pr det from=6
0 device=“04:02.0” name=“NetXtreme BCM5701 Gigabit Ethernet (rev: 21)”
vendor=“Broadcom Corporation” category=“Ethernet controller”
vendor-id=“0x14e4” device-id=“0x1645” irq=5 memory=0xDDFF0000-0xDDFFFFFF
but now these’s v3.1 which upgraded from v2.9.49, It should be supported.
from version 2.9.28 and Higher
  • What’s new in 2.9.28:
*) fixed bug - user-manager could crash on RB100 and RB500;
*) fixed bug - hotspot could crash (introduced in 2.9.27);
*) fixed bug - sometimes hotspot login could fail with failure to add queue;
*) fixed bug - file-system cache on RB100 and RB500 was not flushed on reboot
(sometimes “Keep old configuration” on netinstall did corrupt
configuration data);
*) fixed bug - PPP, PPPoE, PPTP and L2TP could not authenticate via MS-CHAPv1 with some
passwords;
*) fixed bug - PPP, PPPoE, PPTP and L2TP on lost carrier did not correctly report disconnect
cause;
*) added support for Broadcom 5753, 5789 and 5704S2 LAN chips;
*) added support for Novatel U730 (Wireless HSDPA Modem);
*) fixed route redistribution with more than one BGP peer (routing-test);
*) fixed bug - sometimes not all routes were removed after BGP peers went down;
*) fixed some crashes in routing-test;
*) added “blackhole” routes (routing-test);
*) added named time zone support;
*) added ‘reset-mac’ command for ethernet interfaces;
*) fixed min-runtime and on-line for APC USB UPS;
*) added support for Recv-Limit-Gigawords and Xmit-Limit-Gigawords
Radius attributes for hotspot;
*) added options for contolling nexthop selection in BGP updates;
*) user manager - added log section to web interface
*) user manager - result message for enable/disable operations improved
*) user manager - added reports for single user
*) user manager - GUI improvements
*) user manager - page for users (statistics, settings)
*) user manager - reports for unlimited users
