Broken script since 2.9 to 3.9 upgrade
Hi All
I’ve had this bit of script working fine in 2.9, but now in 3.9 it does not seem to work
{/ip route set [/ip route find dst 0.0.0.0/0] gateway 192.168.15.254}
Any ideas?
Thanks in advance
Glen
Try something like this
/ip route set [/ip route find dst-address="0.0.0.0/0"] gateway="192.168.15.254"
-Louis
Hi Louis
Thanks for the reply. I’ve tried your suggestion, but still not working.
Any other ideas?
Glen
is your 0.0.0.0/0 route dynamic or static?
Do you get an error message when you try to change it from CLI?
You can only set/edit static routes.
-Louis
It’s a static route, and I don’t see andy errors if I run the same command from the terminal…
I’m considering going back to 2.9, but I’ve not got the downgrade feature to work yet either!
Glen
This works correctly under ROS 3.7:
:local found
:set found "0"
:set found [/ip route find dst-address="0.0.0.0/0"]
:if ($found = 0) do={
        :log info "Dst-Address not found. Adding.";
        /ip route add dst-address=0.0.0.0/0 gateway=192.168.15.254; }
:if ($found != 0) do={
        :log info "Dst-Address found. Updating.";
        /ip route set $found gateway=192.168.15.254; }
Enjoy!
-Krige
