hi,
i have 2 SXT 5 GHz whose plastic shell is broken. the radios inside are perfectly fine and in great working condition.
can anyone suggest me any integration ideas so i can use those radios with external antennas.
hi,
Check out BalticNetworks.com for cases and antennas. Also roc-noc.com has a good verity too.
thank you.
will check it out right away.
problem is shipping cost. i am based in india. ![]()
In that case.. Here is the list of distributors in India:
http://www.mikrotik.com/buy/asia/india
I’m sure one of them has a good selection.
hi david,
thank you for the reply.
most unfortunate part is in India no one tries or even wants to do something different.
they are just expert in pushing the Mikrotik boxes in as is where is condition.
if you really try probing any of the distributors they all are like " if it is on Mikrotik website (Routerboard.com) we have it, else forget it "
i hope they improve in coming days…
the SXT latch of the new devices are really of bad quality i have 3 already broken while opening it first time from the new pack.
Why not just move it into a pvc box? Use some hot glue for permanent fix…Why buying antenna if only the plastic is broken?
your idea is great but it does not make the unit presentable.
also i was thinking of using it with external antenna mod for longer distance.
so what do you do when the latch on the SXT door is broken?
cannot discard the unit as it is in working condition.
help requested… can i get a replacement cover?
