Browsing & Downloading
I want to make something in my mikrotik server that make browse with full speed and download limited to his profile speed
eg. when user browse any website contain html , jpg , (website) i want to make this browse very fast with the line speed but if he downloaded or use youtube it will be like his profile speed
So i need script to make browsing very speed so there is alot of types of images and website
Like : html,php,html5,jpg,png,gif
Could someone help me?
my mikrotik version 5
any help pleasee
from the router perspective, Technically there is no difference in downloading vs browsing. Router sees it as packets.
However you you can adopt few tricks to overcome the situation.
  • Mark specific type of contents like .zip or .flv and create queue accordingly
  • In mangle section, you can use connection-byte option
Both option works fine,.
I’m doing this on almost all my QoS.
Connection-bytes is option you must use. Mark first few MB of every connection with one packet-mark . (first few MB usually is enough for all Browsing). and mark rest of connection with other mark.
Then use Qeueus to prioritize first MB over all other. This way download will slow down, and browsing will be fast.
how i can make
i saw before an rule in layer7 to make facebook packets to queues then queus give the full speed
but i need the correct one ex : facebook.com|fb.com|fbcdn.com|fbcdn.net
and i need layer7 for all browsing layer7 rule , i need help
i’m waiting your reply
Regards
can you share this for me
Regards
I can help with some pointers, so try to configure yourself and paste configuration.
Then help me with it
i want to create layer7 for facebook and browsing and make this layer7 with queues with unlimited speed to make browsing very fast
i want to anyone make this for me with an rule
Regards
Regards
