Dear All,
I am facing a problem and tried to find out but failed to recover it. I am using RB450G router for bandwidth controlling. I am using just simple queue limitation.
If I use this router board for bw control for simple queue, then after 2/3 hours no body can browse anything. I check the speed by torch for Local LAN port. Everything is okay for first 2/3 hours. after that if some one try to browse or download, he couldn’t get any speed or get the internet connection.
where is the problem, I am unable to find it. I reset the full configuration and re-config the simple queue. but same thing happened.
please any solution…
