Somebody can tell why if mikrotik set up by default port and set it up with the Pubic IP,
somebody try to login looks like brute.
anyoe has the explanation?
tx guys…
tx guys…
yes,
Well Know Port is right default ports.
keep your routerOS securely before go to public networks. ![]()
but Why always happen on RouterOS,
It’s doing fine when I use other router,
It Looks like bug or something..
anyone can explain little bit?
tx
RouterOS is not really anything out of the box, not even a router. There is its power. No one can anticipate how and where it will be used…
turn off logging and make it like your other router.
hai fren
i believed, you can find as you want with RouterOS
to long time not see you.
