Hello!
I have used for years the brute force protection that was indicated on MT website, it seem to work.
There are the “old” rules:
https://wiki.mikrotik.com/wiki/Bruteforce_login_prevention
Now I have found this new set of rules:
https://help.mikrotik.com/docs/display/ROS/Bruteforce+prevention
I tried them on my router, but It doesn’t work, since I can do lot of failed attempts in a row, then I got disconnected, but I connect back again and I do more…
Is there a final script that really works?
I have replaced the “old” rules on the input IPv6 because I got blocked almost immediately even if I do a successful login.
I want to apply also in the ipv6 input chain.
I am using Ros 7.11.2
The best protection is not to leave the service ports open to the world…
Have you ever heard of (not outdated) VPNs?
sorry man, but your answer seem a bit aggressive...
Of course I know about VPNs, I own an ISP, I know, thanks. We use outdated VPNs to access our network (L2TP+IPsec).
Since I have put a specific question, can you please stick to the question?
I have left the whole morning with the ssh opened to the world and the "new" scripts, the result is 0 users in blacklist but a lot of failed login attempts.
I will set again the old one and will try again and will post the results.
Thank you
Ok… the title is
Bruteforce protection script
so…
This is the best RouterOS services (only) protection script.
There can’t be a better one. It is immune to any attack on such services, and does not requre any firewall rule.
Remove the ***** on the script… [For other users: the script punishes meaningless copying and pasting… Be careful what you do…]
/ip ser*vice disable [find]
Sometimes is better not to answer a question if you know since start that you aren’t going to help.
Suggesting me to shut down a service, is not the answer. For sure it is a way to secure the router, without doubt!
I need to have the SSH opened, for a handful of reasons, so, since the “old” script works flawlessy in IPv4 world, the very same “old” script dont work in IPv6 since I got blacklisted immediately, even if I cannot complete the login/password process!
Did anyone made some tests too?
thank you
PS: till I found out a solution, I have used this easy solution:
/ipv6 firewall raw
add action=passthrough chain=prerouting
add action=drop chain=prerouting comment=“Protezione servizi su router IPv6” dst-address-type=local dst-port=22,53,80,8291
protocol=tcp
add action=drop chain=prerouting comment=“Protezione servizi su router IPv6” dst-address-type=local dst-port=53 protocol=tcp
I cannot disable SSH completely because we use for our IPv4 management.
