[admin@SW.OG.1] > export
# 2024-10-24 21:41:47 by RouterOS 7.16.1
# software id = WZPE-N3D7
# model = CRS328-24P-4S+
# serial number = HD508BTMHMH
/caps-man channel
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled \
frequency=5180 name=Ch36_20M
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled \
frequency=2412 name=Ch1 skip-dfs-channels=yes
add admin-mac=18:FD:74:A8:66:F9 auto-mac=no comment=defconf name=BRIDGE1 \
port-cost-mode=short protocol-mode=none
set [ find default-name=ether1 ] name=ether01 poe-out=off
set [ find default-name=ether2 ] name=ether02
set [ find default-name=ether3 ] name=ether03
set [ find default-name=ether4 ] name=ether04
set [ find default-name=ether5 ] name=ether05
set [ find default-name=ether6 ] name=ether06
set [ find default-name=ether7 ] name=ether07
set [ find default-name=ether8 ] name=ether08
set [ find default-name=ether9 ] name=ether09
set [ find default-name=ether24 ] advertise=1G-baseT-half,1G-baseT-full \
poe-out=off
/interface vlan
add interface=BRIDGE1 name=VLAN1-R403-intern vlan-id=1
add interface=ether01 name=VLAN2-R403-Heimautomatisierung vlan-id=1
add interface=ether17 name=gast vlan-id=1
/interface bonding
add name=Bond-MacPro slaves=ether07,ether08
/caps-man datapath
add bridge=BRIDGE1 client-to-client-forwarding=yes local-forwarding=yes name=\
datapath1
/caps-man rates
add basic=6Mbps name="GN Only - No B rates" supported=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
/caps-man security
add authentication-types=wpa2-psk comment=.** disable-pmkid=yes \
encryption=aes-ccm group-encryption=aes-ccm group-key-update=1h name=\
R403.security
add authentication-types=wpa2-psk comment=** disable-pmkid=yes \
R403-Homekit.Security
/caps-man configuration
add country=austria datapath=datapath1 distance=indoors installation=any \
mode=ap name=R403-HOME security=R403-Homekit.Security ssid=R403-HOME
add comment="R403 (5Ghz)" country=austria datapath=datapath1 installation=any \
mode=ap name=R403 security=R403.security ssid=R403
add name=WAN
add name=LAN
/interface lte apn
/interface wifi channel
add band=2ghz-g disabled=no name=2.G.20 width=20mhz
add band=5ghz-n disabled=no name=5.A/N.20 width=20/40mhz-Ce
add band=5ghz-a disabled=no name=5.A
add band=2ghz-n disabled=no name=2.N.20 skip-dfs-channels=all width=20mhz
add band=5ghz-ax disabled=no frequency=5680 name=5.AX width=20/40/80mhz
add band=2ghz-ax disabled=no name=2.AX
add band=5ghz-ax disabled=no name=5.G.AX width=20/40/80mhz
add band=5ghz-ac disabled=no frequency=2300-7300 name=5.AC width=20/40/80mhz
add disabled=yes frequency=2412,2437,2462 name=alt.channel-2G width=20mhz
add disabled=yes frequency=5180,5260,5500,5660 name=alt.channel-5G width=\
20/40/80mhz
add disabled=yes frequency=2412,2437,2462 name=channel-2G width=20mhz
add disabled=yes frequency=5180,5260,5500,5660 name=channel-5G width=\
20/40/80mhz
/interface wifi datapath
add bridge=BRIDGE1 disabled=no name=datapath1
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=R403-Clients wps=\
push-button
add authentication-types=wpa2-psk disabled=no name=R403-Heimautomatisierung
add authentication-types=wpa2-psk disabled=no name=R403-AC
add authentication-types=wpa2-psk disabled=no name=security-clients
add authentication-types=wpa2-psk disabled=no name=security-IoT
add authentication-types=wpa2-psk disabled=no name=security-AC
/interface wifi configuration
add channel=5.A/N.20 country=Austria datapath=datapath1 disabled=no mode=ap \
name=Config:5A security=R403-Clients ssid=R403
add channel=2.G.20 country=Austria disabled=no mode=ap name=Config:2G \
security=R403-Heimautomatisierung ssid=R403-2.4G
add channel=2.N.20 country=Austria datapath=datapath1 disabled=no mode=ap \
name=Config:2N security=R403-Heimautomatisierung ssid=R403-2.4G
add channel=2.AX country=Austria datapath=datapath1 disabled=no mode=ap name=\
Config:2.AX security=R403-Heimautomatisierung ssid=R403-2.4G
add channel=2.G.20 country=Austria datapath=datapath1 disabled=no mode=ap \
name=Config.AC security=R403-AC ssid=R403.AC
add channel=5.AX country=Austria datapath=datapath1 disabled=no mode=ap name=\
R403-5G-AX security=R403-Clients ssid=R403-5G-AX
add channel=5.AC country=Austria datapath=datapath1 disabled=no mode=ap name=\
R403-5G-AC security=R403-Clients ssid=R403-5G-AC
add channel=channel-5G country=Austria datapath=datapath1 disabled=yes mode=\
ap name=config-clients-5G security=security-clients ssid=R403
add channel=channel-2G country=Austria datapath=datapath1 disabled=yes mode=\
ap name=config-clients-2G security=security-clients ssid=R403
ap name=config-IoT-2G security=security-IoT ssid=R403-Heimautomatisierung
ap name=config-AC-2G security=security-AC ssid=R403-AC
/ip ipsec policy group
add name=group1
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024 dpd-interval=2m \
dpd-maximum-failures=5 enc-algorithm=aes-256,3des hash-algorithm=sha256
add dh-group=modp1536 dpd-interval=2m dpd-maximum-failures=5 enc-algorithm=\
aes-256,aes-192,aes-128 name=IPsec-Profile-**
add dh-group=modp1024 dpd-interval=30s dpd-maximum-failures=3 enc-algorithm=\
aes-256,aes-192,aes-128 name=Private-S2S-VPNs
/ip ipsec peer
add address=hff0915c2k1.sn.mynetname.net name=G21 profile=Private-S2S-VPNs
add address=** name=**profile=IPsec-Profile-**
/ip ipsec proposal
add auth-algorithms=sha1,md5 enc-algorithms=\
aes-256-cbc,aes-256-gcm,aes-192-cbc,aes-192-ctr,aes-128-cbc,3des name=\
proposal-**pfs-group=modp1536
add auth-algorithms=sha256,sha1 enc-algorithms=aes-256-cbc,aes-192-cbc name=\
proposal-R403 pfs-group=modp1536
add name=VLAN0-DHCP ranges=10.43.210.101-10.43.210.200
add add-arp=yes address-pool=VLAN0-DHCP authoritative=no interface=BRIDGE1 \
lease-time=23h name=DHCP-INTERN
/ip smb users
/port
set 0 name=serial0
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/caps-man manager
set ca-certificate=auto certificate=auto upgrade-policy=require-same-version
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=BRIDGE1
/caps-man provisioning
add action=create-enabled master-configuration=R403 name-format=\
prefix-identity name-prefix=Prefix- slave-configurations=R403-HOME
/ip smb
set domain=R403
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether01 \
internal-path-cost=10 path-cost=10
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether02 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether03 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether04 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether05 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether06 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether09 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether10 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether11 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether12 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether13 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether14 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether15 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether19 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether20 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether21 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether22 \
add bridge=BRIDGE1 comment=defconf ingress-filtering=no interface=ether23 \
add bridge=BRIDGE1 ingress-filtering=no interface=sfp-sfpplus1 \
add bridge=BRIDGE1 ingress-filtering=no interface=ether16 internal-path-cost=\
10 path-cost=10
add bridge=BRIDGE1 ingress-filtering=no interface=ether17 internal-path-cost=\
10 path-cost=10
add bridge=BRIDGE1 ingress-filtering=no interface=ether18 internal-path-cost=\
10 path-cost=10
add bridge=BRIDGE1 interface=sfp-sfpplus4 internal-path-cost=10 path-cost=10
add bridge=BRIDGE1 interface=sfp-sfpplus3 internal-path-cost=10 path-cost=10
add bridge=BRIDGE1 interface=Bond-MacPro
add bridge=BRIDGE1 interface=sfp-sfpplus2
set udp-timeout=10s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=BRIDGE1 vlan-ids=1
/interface detect-internet
set detect-interface-list=WAN
/interface ethernet switch
set 0 name=SW1-OG
add interface=ether01 list=LAN
add interface=ether02 list=LAN
add interface=ether03 list=LAN
add interface=ether04 list=LAN
add interface=ether05 list=LAN
add interface=ether06 list=LAN
add interface=ether07 list=LAN
add interface=ether08 list=LAN
add interface=ether09 list=LAN
add interface=ether10 list=LAN
add interface=ether11 list=LAN
add interface=ether12 list=LAN
add interface=ether13 list=LAN
add interface=ether14 list=LAN
add interface=ether15 list=LAN
add interface=ether16 list=LAN
add interface=ether17 list=LAN
add interface=ether18 list=LAN
add interface=ether19 list=LAN
add interface=ether20 list=LAN
add interface=ether21 list=LAN
add interface=ether22 list=LAN
add interface=ether23 list=LAN
add interface=sfp-sfpplus1 list=LAN
add interface=sfp-sfpplus2 list=LAN
add interface=sfp-sfpplus3 list=LAN
add interface=sfp-sfpplus4 list=LAN
add interface=BRIDGE1 list=LAN
add interface=ether24 list=WAN
/interface ovpn-server server
set auth=sha1,md5
/interface wifi capsman
set enabled=yes interfaces=BRIDGE1 package-path="" require-peer-certificate=\
no upgrade-policy=suggest-same-version
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=Config:2G \
radio-mac=C4:AD:34:58:8A:AC slave-configurations=Config.AC,Config:2N
radio-mac=D4:01:C3:04:F4:01 slave-configurations=Config.AC,Config:2N
add action=create-dynamic-enabled disabled=no master-configuration=R403-5G-AX \
radio-mac=D4:01:C3:94:99:A1 slave-configurations=R403-5G-AC
radio-mac=D4:01:C3:94:99:A2 slave-configurations=Config.AC,Config:2N
add action=create-dynamic-enabled disabled=no master-configuration=Config:5A \
radio-mac=D4:01:C3:04:F4:02
radio-mac=C4:AD:34:58:8A:AD
radio-mac=D4:01:C3:97:B1:06 slave-configurations=R403-5G-AC
radio-mac=D4:01:C3:97:B1:07 slave-configurations=Config.AC,Config:2N
add action=create-enabled disabled=yes master-configuration=config-clients-5G \
supported-bands=5ghz-ax
add action=create-enabled disabled=yes master-configuration=config-clients-2G \
slave-configurations=config-IoT-2G,config-AC-2G supported-bands=2ghz-g
supported-bands=5ghz-ac
add action=create-enabled disabled=yes master-configuration=config-AC-2G \
slave-configurations=config-IoT-2G,config-clients-2G supported-bands=\
2ghz-n
add address=10.43.210.254/24 comment=defconf interface=BRIDGE1 network=\
10.43.210.0
add address=93.83.243.146/30 interface=ether24 network=93.83.243.144
add address=10.43.220.254/24 interface=gast network=10.43.220.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip cloud advanced
set use-local-address=yes
/ip dhcp-server lease
add address=10.43.210.188 comment="Jal EG Wirtschaftsraum" mac-address=\
48:E1:E9:A9:55:DB server=DHCP-INTERN
add address=10.43.210.34 client-id=1:dc:a9:4:88:53:ba comment="MacBook Erik" \
mac-address=DC:A9:04:88:53:BA server=DHCP-INTERN
add address=10.43.210.181 comment="Jal OG Buero" mac-address=\
48:E1:E9:A9:59:97 server=DHCP-INTERN
add address=10.43.210.182 comment="Jal OG Schlafzimmer" mac-address=\
48:E1:E9:A2:4B:90 server=DHCP-INTERN
add address=10.43.210.183 comment="Jal OG Balkon" mac-address=\
48:E1:E9:A9:6B:99 server=DHCP-INTERN
add address=10.43.210.184 comment="Jal EG Veranda" mac-address=\
48:E1:E9:A2:4E:F6 server=DHCP-INTERN
add address=10.43.210.185 comment="Jal EG Kueche Sued" mac-address=\
48:E1:E9:A9:54:76 server=DHCP-INTERN
add address=10.43.210.186 comment="Jal EG Kueche West" mac-address=\
48:E1:E9:A9:51:6B server=DHCP-INTERN
add address=10.43.210.187 comment="Jal EG Wohnzimmer Nord" mac-address=\
48:E1:E9:A9:6A:93 server=DHCP-INTERN
add address=10.43.210.189 comment="Jal EG Wohnzimmer West" mac-address=\
48:E1:E9:A9:60:5B server=DHCP-INTERN
add address=10.43.210.201 comment="SWITCH HP ARUBA2530 48 POE OG" \
mac-address=A0:1D:48:34:0A:00 server=DHCP-INTERN
add address=10.43.210.35 comment=MacPro6 mac-address=00:3E:E1:BD:F9:55 \
server=DHCP-INTERN
add address=10.43.210.100 client-id=1:f0:92:1c:e7:4c:90 mac-address=\
F0:92:1C:E7:4C:90 server=DHCP-INTERN
add address=10.43.210.203 mac-address=48:A9:8A:47:38:14 server=DHCP-INTERN
add address=10.43.210.91 client-id=1:4:79:b7:b0:1a:f1 comment=\
"Wechselrichter Kostal" mac-address=04:79:B7:B0:1A:F1 server=DHCP-INTERN
add address=10.43.210.92 client-id=1:0:d0:93:4d:41:11 mac-address=\
00:D0:93:4D:41:11 server=DHCP-INTERN
add address=10.43.210.212 client-id=1:d4:1:c3:94:99:9f mac-address=\
D4:01:C3:94:99:9F server=DHCP-INTERN
add address=10.43.210.214 client-id=1:d4:1:c3:97:b1:4 mac-address=\
D4:01:C3:97:B1:04 server=DHCP-INTERN
add address=10.43.210.211 client-id=1:c4:ad:34:58:8a:aa mac-address=\
C4:AD:34:58:8A:AA server=DHCP-INTERN
add address=10.43.210.213 client-id=1:d4:1:c3:4:f3:ff mac-address=\
D4:01:C3:04:F3:FF server=DHCP-INTERN
add address=10.43.210.3 client-id=1:0:8:9b:c3:cb:93 mac-address=\
00:08:9B:C3:CB:93 server=DHCP-INTERN
add address=10.43.210.2 client-id=1:0:8:9b:f1:be:ba mac-address=\
00:08:9B:F1:BE:BA server=DHCP-INTERN
add address=10.43.210.18 mac-address=F0:92:1C:E7:42:0F server=DHCP-INTERN
add address=10.43.210.0/24 dns-server=\
10.43.210.1,10.43.210.11,8.8.8.8,192.168.121.201 domain=r403.local \
gateway=10.43.210.254 ntp-server=10.43.210.254
set allow-remote-requests=yes cache-max-ttl=1h servers=8.8.8.8
add action=accept chain=input dst-port=4443,8291 protocol=tcp
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=forward protocol=icmp
add action=accept chain=forward disabled=yes dst-address=192.168.0.0/16 \
src-address=10.43.210.0/24
add action=drop chain=forward disabled=yes dst-address=10.43.210.0/24 \
src-address=192.168.10.0/24
add action=accept chain=forward dst-address=10.43.210.0/24 src-address=\
10.21.0.0/24
add action=accept chain=forward dst-address=10.21.0.0/24 src-address=\
10.43.210.0/24
add action=accept chain=forward dst-address=10.43.210.1 dst-port=443 \
protocol=tcp src-port=443
add action=accept chain=forward dst-address=213.33.98.136 dst-port=53 \
protocol=udp
add action=accept chain=input dst-address=10.43.210.2 dst-port=5000 \
in-interface-list=WAN protocol=tcp
established,related,untracked
invalid
add action=accept chain=input comment="defconf: accept in ipsec policy" \
in-interface=all-ppp ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=accept chain=input in-interface=ether24 protocol=ipsec-esp
add action=accept chain=input dst-port=500,1701,4500 in-interface=ether24 \
protocol=udp
in-interface-list=!LAN
add action=accept chain=dstnat dst-address=10.43.210.11 dst-port=443 \
in-interface=ether24 protocol=tcp
add action=accept chain=srcnat dst-address=10.21.0.0/24 src-address=\
10.43.210.0/24
add action=accept chain=srcnat dst-address=192.168.0.0/16 src-address=\
10.43.210.0/24
add action=dst-nat chain=dstnat comment="Forwarding rule" dst-port=5000 \
in-interface-list=WAN protocol=tcp src-port="" to-addresses=10.43.210.2 \
to-ports=5000
add action=masquerade chain=srcnat out-interface=ether24
/ip ipsec identity
add peer=G21
add comment=HalloWelt403 mode-config=request-only peer=**
/ip ipsec policy
set 0 disabled=yes proposal=proposal-**
add dst-address=192.168.10.0/24 level=unique peer=**proposal=\
proposal-**src-address=10.43.210.0/24 tunnel=yes
add dst-address=192.168.121.0/24 level=unique peer=**proposal=\
add dst-address=192.168.122.0/24 level=unique peer=**proposal=\
add dst-address=192.168.70.0/24 level=unique peer=**proposal=\
add dst-address=10.21.0.0/24 peer=G21 proposal=proposal-R403 src-address=\
add dst-address=192.168.50.0/24 level=unique peer=**proposal=\
proposal-*src-address=10.43.210.0/24 tunnel=yes
/ip proxy
set max-cache-size=100000KiB
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
93.83.243.145 pref-src="" routing-table=main scope=30 \
suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=10.0.0.0/8
set ssh address=10.0.0.0/8
set www-ssl address=10.0.0.0/8 certificate=cert1 disabled=no port=8443
set winbox address=10.0.0.0/8
/ip smb shares
set [ find default=yes ] directory=/flash/pub
/routing bfd configuration
add disabled=no interfaces=all min-rx=200us min-tx=200us multiplier=5
/system clock
set time-zone-name=Europe/Vienna
/system identity
set name=SW.OG.1
/system logging
add topics=debug,dhcp
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address=178.189.127.148
/system package update
set channel=testing
/system routerboard settings
# Firmware upgraded successfully, please reboot for changes to take effect!
set auto-upgrade=yes
/tool graphing interface
add
