I bought a brand new RB SXT 5HPnd to replace my older one RB SXT 5HnD which was my AP on my wireless connection.
Onthe client side I have a other RB SXT 5HnD.
I made the wireless connection, but however the BT fails. Also the wireless connection is poor!
When I am on the clients side and try a BT I get Tx/Rx 10s Average 12.0 kbps/19.2 Mbps
But when I am on the Server side and try to make a BT unfortunately I can’t connect!
Does anyone know why that is?
What information should I post here for getting help? what are the necessary terminal commands?
a) On the AP side:
ip firewall filter print
0 ;;; default configuration chain=input action=accept protocol=icmp
1 ;;; default configuration chain=input action=accept connection-state=established
2 ;;; default configuration chain=input action=accept connection-state=related
3 ;;; default configuration chain=input action=accept in-interface=wlan1-gateway
b) On the client side
/ip firewall filter print
0 chain=forward action=accept log=no log-prefix=“”
1 chain=input action=accept log=no log-prefix=“”
Do I have something wrong ?
and… how to add input rule accept on port 2000 ? …is there a easy command for that?
Another question is, can it be because my AP is in older version then my client? [ AP v6.40 Current Firmware 3.41 ] - [ Client v6.46.4 Current Firmware 6.46.4 ]
Why my TX is so less? Tx/Rx 10s Average 12.0 kbps/19.2 Mbps } on which it depends ?
Why my PTP Bridge AP is not connected to my PTP Bridge CPE in the Bandwith Test Tab ?
… I want to check if my connection has really a poor upload or not. Are they other methods to check it?
