Btest Error in direction when placed both way!!
Error in direction when placed both way, when he says rx is actually is reality tx, and vice versa, testing Windows 7 when it is in one direction for both rx and tx is ok
I don’t see what is wrong.
You are uploading at 65Mbps. That is traffic received by the router interface, abbreviated RX. You are downloading at 35Mbps. That is traffic sent by the router interface, abbreviated TX.
thank fewi for you answer
When Btst from the pc shows tx in the router should show rx, the error is (on the pc TX 30 mbps and router TX 30 mb ) is that the error is equal to pc route TX TX
Where do you see that in your screenshot? It shows “arrow down” (download), and in the incoming column in DU, at 35Mbps. That’s RX, received. The router shows 35Mbps TX at the same time.
is correct but shows btest tx?
btw! sorry for my little English
see what I mean (both way wrong and one way is OK)
