BTH Testing Fassing Issue
Dear Sir,
I have enabled BTH,
and Install wireguard client on Windows. I want to access my router via Winbox and access my LAN network. how I can access all resources on my LAN.
when I activate wireguard on my windows. my internet is off. And I have seen in BTH interface there is no gateway etc.
i have attached screenshot for details:
As far as I can see, your port number doesn’t match, that should be the same if im right.
The different ports may be right – it’s proxied after all.
Is the router’s firewall the default, or is there some customizations? Maybe post your config.
In my case I can see that port number is the same on router and client device. This is configured automatically by BTH app.
