BTH VPN WIREGUARD is not in chr
when do we expect it , Are we expecting it?
CHR, well if you are using CHR at home and not in a VPS, cannot help you.
The idea of CHR is to acquire a public IP address or at least a public WANIP in a specific geographic location.
The key being you no longer need BTH because regular wireguard will work just fine.
Good point that it should be included in case one is use CHR behind a non-public IP… probably they didnt think of it??
I believe BTH is limited currently to arm and Tile devices, so there may be other limitations at play..
