Buffer Overflow
Guys,
RB-532,
Version: 2.9.23
On log:
message.cpp:223 ERROR:MEssage:putHeader() - buffer overflow
Nowbody can surf.
Coulkd you help pls?
Fernando
something wrong on client side, webproxy says that some clients send garbage data in headers. run torch and see what is happening. try disconnect some clients
All customers reoriented.
Systems without clients connected, only ny machine
The error log persist
Ideas?
New Data:
Torch: Shows NO TRAFIC, only mine.
CPU Load: 85% Avg.
Pls, Guys, NEED HELP, this matter is important for my company.
More Info from PPP Active connections
Each pppop-client connected is present 6 times, with 30 minutes of uptime diference between each of them.
PPPoE Clients are ADSL Modems Micronet SP3351, its works fine since 2.9.5 version.
Now after upgrade this rare behavior.
Thanks for your help[/img]
System on Comma 4.
CPU Load 99%
New Error: Connection.cpp:138:ERROR:getsockopt() - Invalid File or Directory
PLS, what its happening?
If it’s so critical… Make a support output and send it to mikrotik. Your quickest bet to fix this is to just reinstall it…
Provided you backup your configurations like you should, the excersize won’t even take 10 minutes.
System geting worst
[fvazquez@Nodo Pilar] > ip
[fvazquez@Nodo Pilar] ip> ipsec
[fvazquez@Nodo Pilar] ip ipsec> pri
no such command or directory (pri)
[fvazquez@Nodo Pilar] ip ipsec> peer
[fvazquez@Nodo Pilar] ip ipsec peer> pri
Flags: X - disabled
error - contact MikroTik support and send a supout file (2)
Fernando
Try reinstalling with netinstall or send support file to mikrotik
Maximiliano
Mikrotik Certified
Intercity SRL
Rio Cuarto-Argentina
maybe your hardware is dead. i suggest you replace it with another router, export your config as soon as you can (/export file=aaa), you will need it on the new router. don’t import it there, just open with a text editor to see what you need to reconfigure in the new router.
Some rare situation is in place now
I disabled the web proxy and all is working fine.
I´ll try to re install with netinstall, and let you know.
The VPN is working without problems
I donk think that harware be a problem.
I´ll keep you informed of the results, thanks
Fernando
Hi guy´s.
System upgraded to Version 24
All systems returns to life.
´The problem was not hardware.
Great job, GUYS
Fernando
