BUG: Bridge not work with MTU=1500
I work at an ISP I have a network with many QinQ VLANs because we have many services in place.
I recently migrated from a CCR to CHR,
however when I need to pass packets with a size of 1500 with vlans within a vlan within the bridge it does not pass if the packet is 1500, it does not happen when I place the vlans within ether1 directly without a bridge, but I need the bridges for other operations
I made a laboratory to reproduce the problem, I will pass the script from a CHR and RB2011
obs: the proxmox has jumboframe active and working
script to reproduce the problem:
script in RB2011:
/interface bridge add name=bridge1
/interface vlan
add interface=bridge1 name=VLAN1 use-service-tag=yes vlan-id=1
add interface=VLAN1 name=VLAN2 use-service-tag=yes vlan-id=2
/interface bridge port add bridge=bridge1 interface=ether1
/ip address add address=192.168.1.2/24 interface=VLAN2
CHR script that doesn’t work:
add name=bridge1
/interface vlan
/ip address add address=192.168.1.1/24 interface=VLAN2
/ping 192.168.1.1 size=1500
CHR script that works:
/interface vlan
add interface=ether1 name=VLAN1 use-service-tag=yes vlan-id=1
I know the answer will be: so use it without a bridge, but I need them to bridge other interfaces
Can you please test with smaller packets as well? Quite a while ago, I encountered similar issue, where VLAN-tagged packets were not passing through the bridge in CHR but everything worked fine when I bound VLAN to an ethernet interface. All details here: http://forum.mikrotik.com/t/chr-does-not-transmit-frames-with-vlan-tags-from-bridge/127278/1
If it does not work for you even with smaller packets, it is a proof the proxmox is suffering from the same issue as hyperV where I encountered this bug and it is not about size, but about VLAN and bridge… Since then, I switched CHR to an ESXi and it works fine now.
Just to make sure, I tested your situation with my live CHR on ESXi (sorry, no lab equipment ATM) and I can easily send large (8500) packets through VLAN which is assigned to the bridge.
So it is definitely NOT global bug.
yes, with smaller packet 50 works, this fails only when i need to ping in vlan inside vlan with mtu1500
