BUG CHR License management
Dear,
I just noticed that my CHR is not longer updating. (License purchased in september this year)
I’m able to login to my Mikrotik account from the CHR but the license stays in the ‘Limited Upgrades’ state?
The first thing I would like to check is the license in my Mikrotik account. Here I come across the following problem:
  1. After logging in, I am required to change my password as it has been a long time ago.
  2. After I try to change my password to use the functions, I get an error: “Detected multiple open forms, please close all other windows and repeat the procedure!
In the meantime I have tried everything and am a bit distraught.
Help?
I have same problem after login into account.
Email support, they will be the only ones that can help you with licensing
Sent from my SM-A520W using Tapatalk
Me too.
Any sugestion?
