I just upgraded from 5.25 to 6.1.
- I have copied all files from unpacked all_packages-mipsbe-6.1.zip into RB750GL and rebooted.
- Next I disabled IPv6, Multicast, LCD, UPS, Calea, Wireless, Openflow, GPS, Hotspot and reboot
- But after reboot it looked in WebFig that all packages are enabled - even though that they were marked by X (as disabled)
- Next I uninstalled these packages, and finally they get disabled.
- And next I wanted also disable Routing, so I uninstalled routing package. But after reboot the Routing menu is still present.
Questions:
- Is there known issue with disabling packages in 6.1 RouterOS?
- Can somebody try to disable some package and verify if it works?
- Is routing package mandatory, so it cannot be uninstalled
