BUG? export for interface bridge vlan not correct
Currently using 6.42.6 on a CRS317-1G-16S+.
Configured vlans in the bridge menu, everything ok.
Now I wanted to backup my configuration and ran a /export.
But it’s missing the current-tagged and current-untagged configuration!
/interface bridge vlan
add bridge=br-VLAN tagged=sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,sfp-sfpplus5,sfp-sfpplus6,sfp-sfpplus7,sfp-sfpplus8,sfp-sfpplus9,sfp-sfpplus10,sfp-sfpplus11,sfp-sfpplus12,sfp-sfpplus13,sfp-sfpplus14,sfp-sfpplus15,sfp-sfpplus16,ether1,br-VLAN vlan-ids=\
    15,13,10,20,30,40,50,60,70,80,90,100,110,120,130,140,150,2550,2551
[admin@cs] /interface bridge vlan> print
Flags: X - disabled, D - dynamic
 #   BRIDGE        VLAN-IDS  CURRENT-TAGGED        CURRENT-UNTAGGED
 0   br-VLAN        15        br-VLAN        vlan80-Management
        13        sfp-sfpplus2
        10        sfp-sfpplus3
        20        sfp-sfpplus5
        30        sfp-sfpplus6
        40        sfp-sfpplus7
        50        sfp-sfpplus8
        60        sfp-sfpplus9
        70        sfp-sfpplus1
        80        sfp-sfpplus10
        90
        100
        110
        120
        130
        140
        150
        2550
        2551
 1 D br-VLAN        1        sfp-sfpplus10
After importing the exported line:
 0   br-VLAN        15
        13
        10
        20
        30
        40
        50
        60
        70
        80
        90
        100
        110
        120
        130
        140
        150
        2550
        2551
Any hints?
The current-* values under /interface bridge vlan are dynamic values, they are generated based on your PVID and untagged ports. These dynamic values should only be used for monitoring purposes.
Thanks, but my fault was I didn’t enable the VLAN Filtering! when enabled it showed correctly
