bug findings----users help needed :lol:
i have arequest to people that know how to use wiki
can we add a tab in for bug finding
so if we find a bug we can add it to the list
and mikrotik can work on it as not all support .rifs get worked on
then mikrotik can maybe add in date to the bugs we know about to when we can expect the to be fix
as i have 3-4 outstanding bug since 3.25 and still not fixed in 4
what do the people think of this?
do thay think this will work will people update to help fix the os
nice idea
not really. what one person thinks is a bug, actuall could be misconfiguration. also, from experience, when one person says “my router doesn’t boot”, three other people will say “i have the same problem” even if the first one has no power plugged in, the second has burned it, and the third has not plugged the ethernet wire.
the only good decision is to make web-based bug-tracking system. but moving from the old one to the new one will be hard… and this transition is of doubtful value…
this is why we have a bug tracking system internally, and it’s updated only after going through a “sanity test” by our support department :slight_smile:
otherwise it would be complete chaos
well cant the mikrotik team export a list every now and then of bugs found that us as users can be aware of bugs
as not everyone uses all the features on the board and when we want to try use them we can look on the list of known problems of the diffrent packages so what does mikrotik think of this?
So you assume that we intentionally release versions full of bugs :slight_smile: ?
Interesting assumption. When we find out about a bug, it’s written in the forum, or posted as a notice on the download page. We don’t know about those bugs that have not been found yet :smiley:
no not that just saying!
that it would be nice to have a place were we can look at
were mikrotik can say we have found the following bugs and will be fixed
be aware of the bugs?
and then people will know as many people send the rif file to mikrotik mikrotik replys its a bug and will be fixed
and the person that sent the rif file dont post anything on the forum and it happens time and again
dont you think maybe it would cut back on sum of the emails you get of the same thing over and over again
:smiley: :smiley: :smiley: :smiley:
we currently don’t have plans to build a public bug tracker.
thats no problems as everyone knows you are busy with 100 of things but just think about it it would be nice to have somthing like that thanks for th good work team
Normis, what about adding ‘Known Problems’ section to every version in Changelog?.. so users don’t look through forum in search of solved bugs of previous version…
THAT WOULD NICE! :astonished:
i see mikrotik has found somthing
at from 3.25 nothing happend with 4 small bugs to me were not fixed now 4.1 is out and all of them are fixed
thanks to the team and thanks to [Sergejs] , [Janis Megis] and [Normunds] <support@mikrotik.com>
for the fast email support
as im running well on 4.1 but ill email you if i find any bug?
thanks again team
